How do various loops WebServer example work?
My question is what is the best place to put other than Net tasks.
I am showing data from serial port in a simple web page. Now I use millis() to simulate serial data.
I have a slightly modified WebServer sketch running on a Duemilanove. Currently it seems to work.
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 modified 02 Sept 2015
 by Arturo Guadalupi
 WebServeroma.ino
 16.2.2022
#include <SPI.h>
#include <Ethernet.h>
unsigned long previousMillis, currentMillis;
char str[10];
int number;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Ethernet WebServer Example");
 Serial.println("WebServeroma.ino");
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start the server
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  number=0;
  itoa(number,str,10);
   //Serial.write(str);
  currentMillis=millis();
  // listen for incoming clients
  if (client) {
if (currentMillis - previousMillis >= 10000) {
    //Serial.write("gff ");
  previousMillis=currentMillis;
  number++;
   Serial.write(str);
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
  //  sprintf(str, "%f", number);
      if (client.available()) {
        char c = client.read();
       // Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println(str);
            client.println("<br />");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
In loop() I think. Did I understand the question?
Please click Tools->Auto-format before posting your code next time.
I think you did, but did you notice that my own code is mainly in if (client) loop.
Edit: Serial.Write is for debugging.
Here is code better formatted.
  Web Server
  Circuit:
  created 18 Dec 2009
  by David A. Mellis
  modified 9 Apr 2012
  by Tom Igoe
  by Arturo Guadalupi
  WebServeroma.ino
  16.2.2022
#include <SPI.h>
char str[10];
int number;
byte mac[] = {
  while (!Serial) {
    while (true) {
  // start the server
  server.begin();
  number = 0;
  itoa(number, str, 10);
  currentMillis = millis();
  if (client) {
      number++;
      Serial.write(str);
        // Serial.write(c);
          client.println();
        if (c == '\n') {
    delay(1);
    client.stop();
What do you mean by "if (client) loop" ? Did you mean
The whole code is in post 4, but below is the part I am talking about.
My code is in variable declaration, and in lines 73-76, 84-90, and in line 113.
There is no loop in that part, so maybe I have misunderstood what you meant.
You asked
I said put them in loop(). Did you understand what I meant?
  // <--- Here, for example
  if (client) {
    client.stop();
  // <--- or here
Yes, it looks like I misunderstood your meaning. I'll move the code tomorrow, it is getting late here.
