How do we reduce variation of the coordinates.
Hello everyone, i am doing a indoor positioning project, using 4 anchors, 1 pozyx tag and 1 Arduino Uno R3. I can successfully retrieve the coordinates of the position of the tag(mounted on the arduino ) when i move it around. However, when i place it on the table without moving it the coordinates doesn’t stay or rather it varies a lot like around +/- 200.?
Does anyone know how to reduce the variations and get a more accurate reading.? :slight_smile:
I appreciate your help :slight_smile: Thank you very much
Have you considered averaging the values?
Paul
Values like +/- 200 are completely meaningless without stating the units of measurement.
Hello Paul_KD7HB & jremington Thanks for the reply.
Yes, I have tried averaging the values, but it still deviates too much.
Sorry jremington for my negligence, it is in millimetres. +/- 200mm
Pozyx claims +/- 1 cm accuracy, but you claim to be getting +/- 20 cm.
That is a problem that I would bring to the attention of the Pozyx people.
I do have trouble believing that averaging does not help. Averaging should reduce the standard error by a factor of sqrt(N), where N is the number of samples averaged. So, averaging 16 samples should reduce the standard deviation to +/- 5 cm.
Post your code.
Hi jremington Thank you so much for your reply.
I am a little confused about your statement about implementing a square root to lower the standard deviation.
This is my code
#include <Pozyx.h>
#include <Pozyx_definitions.h>
#include <Wire.h>
////////////////// PARAMETERS //////////////////
uint16_t remote_id ;
boolean use_processing = false;
bool remote = false;
coordinates_t coor;
const uint8_t num_anchors = 4;                                           // the number of anchors
uint16_t anchors_id[num_anchors] = {0x6e6d, 0x6923, 0x6961, 0x6969};     // the network id of the anchors: change these to the network ids of your anchors.
int32_t anchors_x[num_anchors] =   {0,       0,      3420,    3380};       // anchor x-coorindates in mm
int32_t anchors_y[num_anchors] =   {0,      6880,      0,     6130};       // anchor y-coordinates in mm
int32_t heights[num_anchors]   =   {900,      470,     1060,    760};       // anchor z-coordinates in mm
uint8_t algorithm = POZYX_POS_ALG_TRACKING;                              // positioning algorithm to use. try POZYX_POS_ALG_TRACKING for fast moving objects.
uint8_t dimension = POZYX_3D;                                            // positioning dimension. ( 2.5D fixed height, 3D variable height)
int  setOperationMode(POZYX_TAG_MODE, remote_id);                        //to tell the system that the local device is a tag and not a anchor
void setup(){
  while(!Serial); // for the Arduino Leonardo/Micro only
  Pozyx.begin();
  if(!remote){
    remote_id = NULL;
  Serial.println(F("----------POZYX POSITIONING V1.1----------"));
  Serial.println(F("NOTES:"));
  Serial.println(F("- No parameters required."));
  Serial.println(F("- System will auto start anchor configuration"));
  Serial.println(F("- System will auto start positioning"));
  Serial.println(F("Performing manual anchor configuration:"));
  // clear all previous devices in the device list
    Pozyx.clearDevices(remote_id);
  // sets the anchor manually
  setAnchorsManual();
  delay(2000);
  printCalibrationResult();
  Serial.println(F("Starting positioning: "));
  Serial.print("\n");
void loop(){
  coordinates_t position;
    int status;
    Pozyx.begin();
    int32_t height = coor.z;                                                      // height of device
  if(remote){
   status = Pozyx.doRemotePositioning(remote_id, &position, dimension, height,algorithm);
  else{
    status = Pozyx.doPositioning(&position, dimension, height, algorithm);
 if (status == POZYX_SUCCESS){
    // prints out the result
    printCoordinates(position);
// prints the coordinates for either humans or for processing
void printCoordinates(coordinates_t coor){
  if (remote_id == NULL){
    remote_id = 0;
  if(!use_processing){
    Serial.print("POSITION 0x");
    Serial.println(remote_id , HEX);
    Serial.print(", x(mm): ");
    Serial.print(coor.x);
    Serial.print(", y(mm): ");
    Serial.print(coor.y);
    Serial.print(", z(mm): ");
    Serial.println(coor.z);
  }else{
    Serial.print(remote_id ,HEX);
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
  return;
// function to manually set the anchor coordinates
void setAnchorsManual(){
  for(int i = 0; i < num_anchors; i++){
    device_coordinates_t anchor;                     // Define-ing each anchor as a device_coordinates_t object.
    anchor.network_id = anchors_id[i];
    anchor.flag = 0x1;                               // choose that it is an anchor and not a tag
    anchor.pos.x = anchors_x[i];
    anchor.pos.y = anchors_y[i];
    anchor.pos.z = heights[i];
    Pozyx.addDevice(anchor);                         //adds anchor into the device list of the tag.
void printCalibrationResult(){
  uint8_t list_size;
  int status;
  status = Pozyx.getDeviceListSize(&list_size, remote_id);
  Serial.print("list size: ");
  Serial.println(status*list_size);
  uint16_t anchors_id[list_size];
  Pozyx.getDeviceIds(anchors_id, list_size, remote_id);
  Serial.println(F("Calibration result:"));
  Serial.print(F("Anchors found: "));
  Serial.println(list_size);
  coordinates_t anchor_coor;
  for(int i = 0; i < list_size; i++)
    Serial.print("ANCHOR,");
    Serial.print("0x");
    Serial.print(anchors_id[i], HEX);
    Serial.print(",");
    Pozyx.getDeviceCoordinates(anchors_id[i], &anchor_coor, remote_id);
    Serial.print(anchor_coor.x);
    Serial.print(",");
    Serial.print(anchor_coor.y);
    Serial.print(",");
    Serial.println(anchor_coor.z);
There is no coordinate averaging in that code. Try it and post the results.
What do you find confusing about this statement?
Hi jremington, so sorry to trouble you, but thank you so much for your effort to reply and help me.
Maybe your term of " averaging the coordinates " and mine is a little different. Averaging as in adding the coordinates and dividing.?
Averaging, as commonly understood, means to add up N numbers (for example, X-coordinates) and divide the result by N.
Choose a number for N (like 10 or 100) and proceed for X, Y and Z coordinates separately.
Hello jremington, thank you for replying. :)
Alright, i understand where you're coming from right now.
But here's another problem. Let's say for my X Axis, the value for my X Axie is stored inside the variable " coor.x "
each time the void loop() , loops, it produces different X value. So how can i code for it to add up the different X values.? Like for eg, the first time it loops, coor.x = 1000mm , second time it loops, coor.x = 1150, third time it loops coor.x = 1200. when the pozyx isnt even moving, which is the current problem now, when it doesn't move at all the X, Y and Z coordinates varies too much.
Though after each loop the value is different, the variable that stores it is the same. So i don't really know how to code for it.
I am very sure if i just change it like this, the results won't be the expected results.
int avg_x_coor; Serial.print("POSITION 0x"); Serial.println(remote_id , HEX); Serial.print(", x(mm): "); avg_x_coor = coor.x + coor.x; Serial.print(avg_x_coor);
Serial.print(", y(mm): "); Serial.print(coor.y); Serial.print(", z(mm): "); Serial.println(coor.z); }
So i don't really know how to code for the averaging.
i understand where you're coming from now and it makes a lot of sense, just that i am not very familliar with c++ coding, thus i don't know how to code for it. Sorry if i caused a lot of trouble for you.
float avg_x = 0.0;
for (int i=0; i<10; i++) {
   get_new_coordinates(); //or whatever is required
   avg_x = avg_x + coor.x;
avg_x = avg_x/10.0; //calculate the average of 10 X coordinates
