I had a complete prototype of my project built; a 6x3x2 enclosure with 6 potentiometers, and 6 leds. The leds served as simple value references (pwm dim/brighten), and the 0-1023 values are sent into max/msp.
All of this connected in a very messy manner, loosely jammed into the enclosure:
- breadboard
- jumper wires (22-24 gauge stranded wire with solid male ends)
- lots of electrical tape
I wanted to make the project more professional and stable, thus started experimenting with other wire, and soldering instead of tape. I tried 18 gauge solid-core wire; it was too thick and ruined segments of breadboard, so stiff, that bending wires which were soldered to my potentiometers broke many of their pins clean off. I eventually got 22 gauge solid-core wire, but this still only seems fit for prototyping on a breadboard. Fairly frustrated, I'm in need of your wisdom.
I still plan on having the arduino unit as the center of this project, but I have a few questions:
- Should I use stripboard or other prototyping pcbs to replace the unreliable breadboard?
- How can I best implement flexible stranded wire while still connecting to the arduino?
- Am I an obvious example of a newb in need of a proto shield?
thank you for any help you can give
- Eric
