How do you change the baud rate of HC-05?
I am new to Arduino and I would like some help please.
I don't know how to change the baud rate from 9600 to 115200.
I am using an arduino nano and the bluetooth component is HC-05.
I am making one of those Self balancing Robots.
By the way on the Internet people said to go to the serial monitor but by me the serial monitor
does not respond. If someone could also help me there ,that would also be great.
Could someone explain me how to do this from A to Z please.
Thank you already for all your answers.:pray:
Do not change it by AT Command. HC-05 BT works well at default Bd = 9600 for data transfer over SUART (software UART) Port.
This page may be of interest.
I use a HC05 at 115200 on my plotter to transfer gcode from the PC to my grbl enabled plotter. It works fine.
This instruction is for the HC05 module marked ZS-040 connected to an Arduino Uno, Nano or any mega328 based board. Connect the HC05 as shown in the Martyn Currey page linked in my prior post. HC05 TX to Arduino pin 2 and HC05 RX to Arduino pin 3 (through voltage divider).
To change the baud rate you must first put the HC05 into AT mode. Do that by connecting the EN pin to 3.3V, NOT 5V. Then power up the Arduino board and HC05 module. The LED on the module should alternate lit for about 3 seconds and off about 3 second if it enters AT mode.
Upload the following code to the Arduino board.
// To enable AT mode connect the EN pin of the HC05
// to 3.3V.  Caution, do not connect EN to 5V.
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
const long baudRate = 38400;
char c = ' ';
boolean NL = true;
   Serial.begin(38400);
   Serial.print("Sketch:   ");   Serial.println(__FILE__);
   Serial.print("Uploaded: ");   Serial.println(__DATE__);
   Serial.println(" ");
   BTserial.begin(baudRate);
   Serial.print("BTserial started at ");
   Serial.println(baudRate);
   //BTserial.print("BTserial started at ");
   //BTserial.println(baudRate);
   // Read from the Bluetooth module and send to the Arduino Serial Monitor
   if (BTserial.available())
      c = BTserial.read();
      Serial.write(c);
   // Read from the Serial Monitor and send to the Bluetooth module
   if (Serial.available())
      c = Serial.read();
      BTserial.write(c);
      // Echo the user input to the main window. The ">" character indicates the user entered text.
      if (NL)
         Serial.print(">");
         NL = false;
      Serial.write(c);
      if (c == 10)
         NL = true;
In serial monitor (baud rate set to 38400) you should see something like (the file directory will be a bit different):
⸮Sketch: D:\bt_test_AT\bt_test_AT.ino
Uploaded: May 19 2022
BTserial started at 38400
Type "AT" (no quotes) and enter. You may see:
AT
ERROR:(0)
That is normal.
Type "AT" (no quotes) and enter again. Now you should see:
AT
OK
If that is what you see, the HC05 is in AT mode and ready to accept AT commands.
To set to baud 115200, enter "AT+UART=115200,0,0" (no quotes).
Yes, the HC05 can indeed function at 115200 baud, if it is connected to the hardware serial pins 0/1, but if the HC05 is connected to the Nano with software serial, do not take the baudrate higher than 38400.
You connect the HC05 to the hardware serial port of the Nano and use 115200 baud, you will have to remove the connections to load code.
Why do you think your application needs a baud rate higher than 9600?
Wandering down the AT path and using hardware serial may not be a good solution for someone who is self proclaimed to be new to Arduino and needs A to Z instructions.
thanks a lot this has helped me to figure it out.
