How do you compare a 1D array with a 2D array?
I have a pointer being passed as a reference to a function. And this pointer points to 0th element of a 1D array. Now I want to compare it with an 2D array.
This 2D array is a list that will keep generating if any 1D array that is being passed isn't already saved in that list.
How can I implement this?
Multiple calls to "memcmp"
Each element of array needs to be compared. The elements of the array hexadecimal padded to two digits "%02x".
The scenario is as below.
A[0] A[1] A[2] A[3] --- pointer points to first element of this array
B[0] B[1] B[2] B[3] --- array inside the function
Compare A and B. If A == B then save A into B else don't save. So the array B grows as time goes on. Let say until the element size of rows of array B = 2.
B[0][0] B[0][1] B[0][2] B[0][3] --- grows to something like this B[1][0] B[1][1] B[1][2] B[1][3] B[2][0] B[2][1] B[2][2] B[2][3]
So, how to implement this scenario?
See reply #1
If they are the same, why do you need to save duplicate data?
How, exactly, are you going to make the array "grow"? Feed it some array fertilizer?
Because A is stored as a temporary buffer when I receive a data and it is discarded right now. So I want to save them. Its like I have a server which is connected to 9 nodes. So I want to the server to collect all the nodes IP before sending data.
I don't know if you meant it sarcastically or not. I mean it will become a table once all the 9 IPs are stored. In the end it will be array[8][15].
Thanks
Is this the IP address question again? Why 15 bytes to store an IP address when four is perfectly sufficient?
array[8][15].
All nine?
Because that is how it is read from the contiki OS I am using to implement the wireless section of what I am doing.
I'll ask again - why fifteen bytes to store an IP address, when four bytes will suffice? You do know RAM is very limited?
In the beginning, too. Do not plan to create a dynamic mess.
The array WILL be[9][4]!
