How do you detect if the USB cable is connected?
I just found that attempting to read input from Serial Monitor hangs up the sketch if the USB cable is not connected.
Is there a recommended way of dealing with this if it is not possible to detect the presence of a USB connection between PC and Arduino?
100k resistors from digital 1 and 0 to GND so they are not floating without the USB cable connected?
Or is there a way to avoid reading from Serial when the USB cable is not connected.
you are misreading the behavior. Serial.read() will try to read whatever is available or return -1 if there is nothing to read, regardless of the Serial console being opened or not.
you might have a
while(!Serial);
in your setup that gets your code to be stuck if the serial link cannot be established.
(deleted)
spycatcher2k:
check if the buffer has anything THEN read.
As a side comment, I now find this is not the best way. I understand for beginners it gives a safe thought process but it's not very efficient
Serial.available() returns the number of bytes available and does so through some maths in the circular buffer. Serial.read()returns -1 if there is nothing available tor read.
So if your code does not depend on having n bytes already in the incoming buffer (and it should not, you should read as they come in) then I'm now preferring to write
int r;
  if ((r = Serial.read()) != -1) {
    // we received a byte, it's in the LSB of r
which is faster. and in plain english you can understand what it does -->"if I have received a valid byte, then handle it"
