Hey Guys, im pretty new to this so please excuse me if this is a pretty 'stupid' question.
So I am programming a MAX30105 heart rate sensor - Sparkfun with an ESP32 (Hiletgo ESP32 with OLED)
I have programmed the pulse sensor with the Arduino and everything worked perfectly!
But using that same sample code with the ESP 32 instead is not giving me the same result.
So my question is how to interface the sensor with the ESP32 so that it works.
I will attach some sample code that works with the Ardiuno Uno but not with the ESP32.
Example9_RateTesting.ino (2.88 KB)
MAX30105 Breakout: Take readings from the FIFO
By: Nathan Seidle @ SparkFun Electronics
Date: April 8th, 2018
https://github.com/sparkfun/MAX30105_Breakout
Push the MAX30105 as fast as it will go!
We used a Teensy 3.2 for testing. This will configure the MAX3010x and
output at approximately 3200Hz.
On an Uno the fastest we can read is 2700Hz.
Setting required:
Sample average has a direct impact on max read amount. Set to 1 for max speed.
The pulsewidth must be as short as possible. Set to 69.
ledMode must be 1 for 3200Hz. If ledMode is set to 2 max is 1600Hz.
Run at 400kHz I2C communication speed.
Print serial at 115200.
Any serial printing will slow the reading of data and may cause the FIFO to overflow.
Keep your prints small.
Hardware Connections (Breakoutboard to Arduino):
-5V = 5V (3.3V is allowed)
-GND = GND
-SDA = A4 (or SDA) - Pin 18 on Teensy
-SCL = A5 (or SCL) - Pin 19 on Teensy
-INT = Not connected
The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
but it will also run at 3.3V.
This code is released under the [MIT License](http://opensource.org/licenses/MIT).
#include <Wire.h>
#include "MAX30105.h"
MAX30105 particleSensor;
particleSensor.begin();
while(!Serial); //We must wait for Teensy to come online
Serial.println("Max sample rate example");
// Initialize sensor
if (particleSensor.begin(Wire, I2C_SPEED_FAST) == false) //Use default I2C port, 400kHz speed
Serial.println("MAX30105 was not found. Please check wiring/power. ");
while (1);
//Setup to sense up to 18 inches, max LED brightness
byte ledBrightness = 0xFF; //Options: 0=Off to 255=50mA
byte sampleAverage = 1; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 1; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
int sampleRate = 3200; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 69; //Options: 69, 118, 215, 411
int adcRange = 16384; //Options: 2048, 4096, 8192, 16384
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
byte samplesTaken = 0;
long startTime = micros();
while(samplesTaken < 10)
particleSensor.check(); //Check the sensor, read up to 3 samples
while (particleSensor.available()) //do we have new data?
samplesTaken++;
particleSensor.getFIFOIR();
particleSensor.nextSample(); //We're finished with this sample so move to next sample
long endTime = micros();
Serial.print("samples[");
Serial.print(samplesTaken);
Serial.print("] Hz[");
Serial.print((float)samplesTaken / ((endTime - startTime) / 1000000.0), 2);
Serial.print("]");
