How do you interface arduino to 3.3V input pin?
Hi
What is the easiest way to interface arduino output pin of 5V to a sensor input pin of 3.3V?
thanks
I stole this from Grumpy Mike:
Connect a 1.8K resistor from the Arduino pin to the 3.3V input pin
Connect a 3.3K resistor from the 3.3V input pin to ground
In other words, this:
with Z1 = 1800 ohms & Z2 = 3300 ohms
Good luck!
Sparkfun has a good page on this:
http://www.sparkfun.com/tutorials/65
If the sensor has protection diodes a series resistor is the easiest method. Is this a digital or analog connection?
Others use the 74HC125 gates as buffers.
Or the TXB0101/2/4/6/8 chips.
Rob
Its digital data. Will the voltage divider method be good enough, because it is easy than other methods?
If it's 1s and 0s then I think the voltage divider will be fine. I've been using this setup to interface a WiFly serial module with a Duemilanove, Nano, and custom 328 board for a few weeks now with no problems. I confirmed via voltmeter the 5v output from the gets reduced to 3.3v.
Depends on how fast the data needs to change as well.
If you are connecting to a high speed SD card, then the buffer method is better.
DssCircuits.com is for sale | HugeDomains for example
