I'm having a lot of trouble getting this one feature to work. I'm using an MKR WiFi 1010 and the ENV Shield to collect environemental information and I would like to send this data to my server. Ive been hunting down forum threads all day with no solution in sight so hopefully someone knows.
// ArduinoJson - Version: Latest
#include <ArduinoJson.h>
#include <ArduinoJson.hpp>
// ArduinoHttpClient - Version: Latest
#include <ArduinoHttpClient.h>
// Arduino_MKRENV - Version: Latest
#include <Arduino_MKRENV.h>
#include <SPI.h>
#include <WiFiNINA.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wifi radio's status
const String lat = "52.52";
const String lon = "13.41";
const String openWeatherMapKey = SECRET_OPENWEATHER;
WiFiClient client;
float temperature;
float humidity;
float pressure;
float illuminance;
float uva;
float uvb;
float uvIndex;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWifiData();
if (!ENV.begin()) {
Serial.println("Failed to initialize MKR ENV shield!");
while (1);
printCurrentNet();
HttpClient WeatherAPI = HttpClient(client, "api.openweathermap.org", 80);
HttpClient webServer = HttpClient(client, "192.168.178.22", 80);
WeatherAPI.get("/data/2.5/weather?lat=" + lat + "&lon=" + lon + "&units=metric&APPID=" + openWeatherMapKey);
// read the status code and body of the response
int statusCode = WeatherAPI.responseStatusCode();
String response = WeatherAPI.responseBody();
Serial.println("-------------------------------------");
Serial.print("Status code: ");
Serial.println(statusCode);
Serial.print("Response: ");
Serial.println(response);
DynamicJsonDocument Weather(1024);
DeserializationError error = deserializeJson(Weather, response);
if (error)
return;
// Extract values
const float weatherTemp = Weather["main"]["temp"];
const float weatherPressure = Weather["main"]["pressure"];
const float weatherHumidity = Weather["main"]["humidity"];
const float weatherVisibility = Weather["visibility"];
const String weatherMain = Weather["weather"][0]["main"];
Serial.println(F("JSON Response:"));
Serial.println(weatherMain);
Serial.println(weatherTemp);
Serial.println(weatherHumidity);
Serial.println(weatherPressure);
// read all the sensor values
temperature = ENV.readTemperature();
humidity = ENV.readHumidity();
pressure = ENV.readPressure();
illuminance = ENV.readIlluminance();
uva = ENV.readUVA();
uvb = ENV.readUVB();
uvIndex = ENV.readUVIndex();
printSensorReadings();
DynamicJsonDocument mimirJSON(1024);
JsonObject coord = mimirJSON.createNestedObject("coord");
coord["lon"] = 13.41;
coord["lat"] = 52.52;
JsonObject sensor = mimirJSON.createNestedObject("sensor");
sensor["temperature"] = ENV.readTemperature();
sensor["humidity"] = ENV.readHumidity();
sensor["pressure"] = ENV.readPressure();
sensor["illuminance"] = ENV.readIlluminance();
sensor["uva"] = ENV.readUVA();
sensor["uvb"] = ENV.readUVB();
sensor["uvIndex"] = ENV.readUVIndex();
JsonObject weather = mimirJSON.createNestedObject("weather");
sensor["temperature"] = weatherTemp;
sensor["pressure"] = weatherPressure;
sensor["humidity"] = weatherHumidity;
sensor["visibility"] = weatherVisibility;
sensor["main"] = weatherMain;
serializeJson(mimirJSON, Serial);
//Send JSON to server using ARDUINOhttpClient
int len = measureJson(mimirJSON);
webServer.post("/", "application/json", len, mimirJSON);
delay(10000);
void printWifiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
void printSensorReadings() {
// print each of the sensor values
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
Serial.print("Humidity = ");
Serial.print(humidity);
Serial.println(" %");
Serial.print("Pressure = ");
Serial.print(pressure);
Serial.println(" kPa");
Serial.print("Illuminance = ");
Serial.print(illuminance);
Serial.println(" lx");
Serial.print("UVA = ");
Serial.println(uva);
Serial.print("UVB = ");
Serial.println(uvb);
Serial.print("UV Index = ");
Serial.println(uvIndex);
// print an empty line
ERROR CODE:
error: no matching function for call to 'HttpClient::post(const char [2], const char [17], int&, ArduinoJson6113_00000::DynamicJsonDocument&)
There seems to be a problem that the data package when I send it. I'm not sure if its the type, or the some kind of conflict with ArduinoJson, but i'm at the end of my patients for it right now.
If anyone has any ideas I would love to hear them!
