How does my program break this while loop??
pokerdaniel4:
So you are saying there is a ISR method in the library somewhere?
Yes, if you find these files in your computer's Arduino installation folder, you can see how it works: Wire.cpp, Wire.h, twi.c, twi.h.
Your code is fragile at best. You've made a couple mistakes dealing with interrupt code. First all variables shared between ISR and non-ISR code must be declared 'volatile'. Otherwise, the compiler might happily optimize out your intent.
Second, your accesses to the shared variables in the non-ISR code might not be atomic on an 8-bit processor. You should surround them with noInterrupts() / interrupts() pairs.
Finally, the code is rather clumsy. You don't need to share that many variables between the ISR and non-ISR code. The multiple 'if' statements testing for mutually exclusive conditions beg for a 'switch' statement. The use of blocking code in the 'loop()' function is also not desirable. Here's a skeletal outline of what I'd try. It's not complete and won't compile as is. But it should give you an idea of how to go about it.
volatile int c;
volatile bool newValue = false;
  static int localC = 0;
  if (newValue) {
    noInterrupts();
    localC = c;
    newValue = false;
    interrupts();
  switch (localC) {
    case 0:
    case 1:
      servoHev.write(vinkelHev1);
      delay(speed);
      servoRo.write(vinkelRo2);
      delay(speed);
      Serial.println("Båten går fremover en gang");
      servoHev.write(vinkelHev2);
      delay(150);
      servoRo.write(vinkelRo1);
      delay(350);
      delay(speed);
      delay(speed);
    case 8:
      speed -= 100;  // you should put a lower limit on this
      localC = 1;
    case 9:
      speed += 100;  // you should put an upper limit on this
      localC = 1;
    case 2:
      Serial.println("STOPP");
      servoRo.write(8);
      delay(speed);
      delay(speed);
      servoRo.write(8);
      delay(speed);
      delay(speed);
    case 3:
      // stuff for command 3 here
    case 4:
      // stuff for command 4 here
    default:
// void receive_I2C_Event(int) {  // Not the best syntax
void receive_I2C_Event(int numBytes) {        // Better syntax
  while (Wire.available())  {
    c = Wire.read();
    //Serial.println(c);      // Don't use Serial.print inside an ISR
  newValue = true;
