How does one clear SDA1 (fat) errors Yun SD Card on Openwrt Boot?
Problem: SDA1 set to read-only during boot.
Yun SDA1 partition is set to read-only if errors encountered during boot.
Thereafter, sketch cannot write to sda1 partition (/mnt/sda1/arduino/www/) because it is set to READ-ONLY
Modified /etc/rc.local/ to run script at end of boot. note also the ntpdate is installed in luci and runs to set time before exiting. Otherwise time setting seems problematic.
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
ntpdate 216.239.35.12
boot-complete-notify
/usr/sbin/fsck.fat -a /dev/sda1
block mount
exit 0
The fsck problem is described here and similar to this in OPENWRT forum :
[OpenWrt-Devel] [PATCH fstools] block: use fsck.fat instead of dosfsck
Openwrt Forum message states that "dosfsck" is not enabled in Openwrt.
And THIS: reported as a bug, without a solution as yet although a code revision seems available!
Fsck.fat executed, or not? - For Developers - OpenWrt Forum
Read-Only can be cleared if I let Windows scan the SD card in an adapter to clear the fragmenting or what ever error. Bu this little script above seems to solve issues until openwrt is fixed. I will likely add a function in sketches to do the same thing if the sda writes fail as they have been. Not tested there yet, but this works after a few unplugging random tries. :slight_smile:
My Yun System LOG BEFORE:
Thu Apr 9 21:09:35 2020 daemon.err block: check_filesystem: /usr/sbin/dosfsck not found
Thu Apr 9 21:09:35 2020 daemon.err block: /dev/sda2 is already mounted on /overlay
Thu Apr 9 21:09:35 2020 kern.warn kernel: [ 69.135333] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Thu Apr 9 21:09:41 2020 kern.err kernel: [ 75.248738] FAT-fs (sda1): error, fat_free_clusters: deleting FAT entry beyond EOF
Thu Apr 9 21:09:41 2020 kern.err kernel: [ 75.251588] FAT-fs (sda1): Filesystem has been set read-only
SYSTEM LOG AFTER SCRIPT RUNS
Tue Apr 21 21:49:45 2020 daemon.notice procd: /etc/rc.d/S95done: 21 Apr 21:49:45 ntpdate[1548]: adjust time server 216.239.35.12 offset -0.000009 sec
Tue Apr 21 21:49:45 2020 daemon.notice procd: /etc/rc.d/S95done: CP437: No error information
Tue Apr 21 21:49:45 2020 daemon.notice procd: /etc/rc.d/S95done: fsck.fat 4.1 (2017-01-24)
Tue Apr 21 21:49:51 2020 daemon.notice procd: /etc/rc.d/S95done: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Tue Apr 21 21:49:51 2020 daemon.notice procd: /etc/rc.d/S95done:  Automatically removing dirty bit.
Tue Apr 21 21:49:51 2020 daemon.notice procd: /etc/rc.d/S95done: Performing changes.
Tue Apr 21 21:49:51 2020 daemon.notice procd: /etc/rc.d/S95done: /dev/sda1: 9 files, 161/2044002 clusters
Tue Apr 21 21:49:52 2020 daemon.err block: /dev/mtdblock4 is already mounted on /rom
Tue Apr 21 21:49:52 2020 daemon.err block: /dev/mtdblock5 is already mounted on /mnt/mtdblock5
Tue Apr 21 21:49:52 2020 daemon.err block: /dev/sda1 is already mounted on /mnt/sda1
Tue Apr 21 21:49:52 2020 daemon.err block: /dev/sda2 is already mounted on /overlay
Tue Apr 21 21:49:53 2020 daemon.notice procd: /etc/rc.d/S96led: setting up led LAN-LED-On
Tue Apr 21 21:49:54 2020 daemon.notice procd: /etc/rc.d/S99internet-check-service: Start internet-check
Tue Apr 21 21:49:55 2020 daemon.notice procd: /etc/rc.d/S99usd: Start uSDaemon
Tue Apr 21 21:49:55 2020 daemon.info procd: - init complete -
Moved your topic to it’s current location / section as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Thank You. got it.
