I'm working with AVR microcontrollers in Atmel Studio and I'd like to put some code in a "library" directory to be able to include this code in my future projects. I would like to #include <some_module.h> in my projects and let the compiler/linker do they work with no extra compilation flags. In GCC there's no easy way of doing this, but Arduino does exactly this. We put some .cpp and .h files in a library directory once, and from that moment on we can just #include <some_module.h> and every thing goes right.
What magic does Arduino do? Can anyone help me with this?
We can #include <some_module.h>, using <> if some_module is part of a precompiled library placed in specific directories. Also, I think there's some flags that should be used in the compilation and linking process.
But what I want is to #include <some_module.h>, just like Arduino does, with non precompiled library files, and without user extra configuration at compile time.
Arduino has a standard structure and place for "libraries", filesystem and naming-wise. So when you say "#include <NAME.h>" in your source code, the IDE parses that before the compile, and adds "-I/lots/of/file/path/stuff/NAME/src/NAME.h" to the compile command, and it copies "/lots/of/file/path/stuff/NAME/src/NAME.cpp" along with possibly other stuff (/lots/of/file/path/stuff/NAME/utility/*.c", etc) to the build directory so that it can be compiled along with your sketch.
It's a lot like using ASF Explorer in Atmel Studio. You've tell the IDE that you want to use a particular feature, and it goes and gathers the various bits and either puts them where you need them, or figures out where they are and adds that info into the build. AS uses the project files to hold the info, Arduino manages to sneak it into the source file (by being restrictive about name/library mapping/etc.)
Thanks, westfw. Very useful answer. You put me on the tracks.
Could you please link some documentation, libraries, or any other resource that you think can help me learning more about that (the Arduino thing, not ASF)? Since Arduino Software is GPL and LGPL, I'm thinking about use it in a project I'm working on, but I really don't know where to start.
I'm not sure exactly what you're asking for but this is the repository for the tool that does the Arduino IDE's include magic (as well as other things):
