Hi all! I know that probably this question might be dump but I've read tons of articles about external power supply and I still can't figure it out.
My question is this;For what reason is the Vin pin ? You put an external power supply or you get from the pin more volts?????
But in both cases there is a problem...If you put an external power supply to the pin from where you'll take the voltage?( i hope i am not too confusing)
If from the other side take from that pin where do you put the externall power supply ???? (i hope i am not too confusing again :))
Please repply so that i will be able to understand 8)
