how faithful is this code to RTC?
hello
i am making a master clock, and i am using the following code. if i am correct, in the void setup the code syncs the system with the RTC only on startup.... however i believe i should be syncing to the RTC more frequently and/or using only the RTC time and not the system clock. is this possible? what would be the most accurate way to send a pulse every minute over a long period... any suggestions would be greatly appreciated :o
#include <DS1307RTC.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <Wire.h>
int enA = 10;
int in1 = 9;
int in2 = 8;
    digitalWrite(in1, HIGH);
    digitalWrite(in2, LOW);
  Serial.println("In setup....");
  using rtc, sync system time to rtc
   setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011 //old way *****************
  // following lines added to set time from rtc, took from timeRtcSet example, added jim *****************
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if (timeStatus() != timeSet)
    Serial.println("Unable to sync with the RTC");
    Serial.println("RTC has set the system time");
  // end of setting the time ******************************
Alarm.timerRepeat(60, Repeat);            // pulse every 60   seconds
  pinMode(enA, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  digitalClockDisplay();
  Serial.println("Ending setup....");
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void Repeat() {
  digitalWrite(enA, HIGH);
  Serial.println("PULSE");
  digitalWrite(9, !digitalRead(9));  // toggle state
  digitalWrite(8, !digitalRead(8));
  digitalWrite(enA, LOW);
void  loop(){
  Alarm.delay(1000);
The default sync interval is 300 seconds (5 minutes). You can change it with setSyncInterval().
hey john!
thanks for the reply. so as is, it syncs every 5 min? even though the sync with rtc is in the void setup? if so, thats perfect. thanks again
