I want to switch my 4-channel relay module on and off quickly to control my active buzzer. Do you know what the switching frequency of the relay modules (the link is below) is? Can I switch the relay with a frequency of 5 or 2 Hz?
I see all the replies but am trying to get information. Btw, the system will not run a buzzer at 2-5 Hz for hours. The situation rarely occurs. In the normal situation, the buzzer remains silent.
In this kind of situation, I like to consider the wise words of Dr. Ian Malcolm. Paraphrasing slightly:
"You're spending so much time thinking about whether you could, you didn't stop to consider whether you should"
The relay module is probably not an appropriate way to control a "buzzer" and obviously a four relay module is not sensible unless you already have uses for the other three relays in the module.
But you have failed to cite the buzzer itself which determines the most appropriate way to actually switch it.
