Application:
There is one shaft (Roller1) that will be turning at a rate which is open loop, monitored, possibly varying, but not by much. It is simply hooked up to a DC motor and it is monitored with an optical encoder for the purpose of turning another shaft (Roller2) at the appropriate rate. Roller2 must turn at a rate which is a function of Shaft1's current angular velocity AND the total angle it has turned...because the diameter of one of the rollers is changing as film is rolled onto it.
Implementation:
This has to happen fast and be precise or error will stack up. What I was originally going to do, was every "small time interval" of say 50ms, I would
grab the small-time-interval-averaged/roughly instantaneous Roller1 angular velocity and its integrated total angle
based on this, calculate what we know the Roller2 speed SHOULD be (this will be changing even if Roller1's speed is constant)
Use PID to adjust the Roller2's DC motor speed to match the calculated value--Roller2 has an optical encoder as well.
I was going to use the PID_Beta6 library in the Playground. I had assumed that if I ran Compute() once per 50 ms small-time-interval, it would compute me an Output no matter what, so that I would be readjusting Roller2's speed every 50ms, keeping up with the changing diameter. I cannot afford to wait 1s. But now I think the library will only Compute() once per second by default. If you create with advanced options, there is a "SetSampleTime(int NewSampleTime)" method that will let me set the SampleTime down to 1ms. However now I have to ask, if I am doing this at such a high rate, should I be using the PID library at all, or should I write my own PI function?
I could SetSampleTime(1) and then the PID would calculate an Output every time I ran my loop. I'm just wondering if it makes sense to do this, or if I need to operate so fast, if using PID doesn't really make sense anymore.
