How get Joystick value from Transmitter?
Hardware:
2 Arduino UNO
2 Arduino Wireless SD Shield
1 Arduino Motor Shield
1 SaintSmart Joystick
2 XBEE S1
How get Joystick value from Transmitter? My does not work.
Transmitter (simple code)
int VRx = A4;
int valx;
int joyValx;
int fspeed; // Forward speed
int bspeed; // Backward speed
  joyValx = analogRead(A4);
  if (joyValx >= 500 && joyValx <= 505) {
    Serial.write('s'); // Motor stop
  if (joyValx < 500) {
    fspeed = map(joyValx, 500, 0, 0, 255);
    Serial.write(fspeed);
  if (joyValx > 505) {
    bspeed = map(joyValx, 505, 1023, 0, 255);
    Serial.write(bspeed);
  delay(100);
Receiver (simple code)
// Arduino Motor Shield
#define PWM_A 3
#define BRAKE_A 9
#define DIR_A 12
int fspeed;
int bspeed;
  pinMode(PWM_A, OUTPUT);
  pinMode(BRAKE_A, OUTPUT);
  pinMode(DIR_A, OUTPUT);
  while(Serial.available()){
    char getData = Serial.read();
      if (getData == fspeed) {
        Forward();
      if (getData == bspeed) {
        Backward();
      if (getData == 's') {
        Brake();
void Forward() {
  digitalWrite(DIR_A, HIGH);
  digitalWrite(BRAKE_A, LOW);
  analogWrite(PWM_A, fspeed);
void Backward() {
  digitalWrite(DIR_A, LOW);
  analogWrite(PWM_A, bspeed);
void Brake() {
  digitalWrite(BRAKE_A, HIGH);
  analogWrite(PWM_A, 0);
From the receiver part:
fspeed is a not initialized variable as is bspeed a few lines below. Do you really expect that this comparison does something useful?
