How get this code to read strings over 9 characters from serial?
hi all,
My code constructs string commands from serial input. However, the command is not picked up when the total length is longer than 9 characters.
How do i extend this?
String cmd;
void setup(){
  cmd = "";
  serialReader();
void serialReader(){
  int makeSerialStringPosition;
  int inByte;
  char serialReadString[300];
  const int terminatingChar = 13; //Terminate lines with CR
  inByte = Serial.read();
  makeSerialStringPosition=0;
  if (inByte > 0 && inByte != terminatingChar) { //If we see data (inByte > 0) and that data isn't a carriage return
    delay(10); //Allow serial data time to collect (I think. All I know is it doesn't work without this.)
    while (inByte != terminatingChar && Serial.available() > 0){ // As long as EOL not found and there's more to read, keep reading
      serialReadString[makeSerialStringPosition] = (char) inByte; // Save the data in a character array
      makeSerialStringPosition++; //Increment position in array
      //if (inByte > 0) Serial.println(inByte); // Debug line that prints the charcodes one per line for everything recieved over serial
      inByte = Serial.read(); // Read next byte
    if (inByte == terminatingChar) //If we terminated properly
      Serial.println("command received");
      serialReadString[makeSerialStringPosition] = 0; //Null terminate the serialReadString (Overwrites last position char (terminating char) with 0
      cmd = serialReadString;
      Serial.println(cmd);
Thank you!
Begin with getting rid of the String class and all instances of it.
  serialReader();
Unless this is the start of a larger project, or trimmed down code to illustrate a problem, calling just one function from loop() is unnecessary overhead.
You don’t know that there is anything to read.
I’d recommend NOT using compound statements in this if statement. Nested ifs, in this case, are far easier to understand.
You really need to understand why, and get rid of this. Waiting around for each character is a waste of time.
Looping UNTIL a specific character arrives is a whole different story.
This code will read all the serial data and store it in an array, without a single String or delay:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
You can change the SOP and EOP values (or remove the SOP and started stuff),
You can move the while code to a separate function, in a while(!ended) loop, and return when ended is true.
You're right with your comments, instead of correcting it I went for yours.
Thanks!
