hello every one
i have a thermal printer with cutter for paper
i use it for printing text en barcode and other thing
now i use it on one project and i don't find any information for do ordering it to cut paper when is end
this printer is work with UART interface with bauderate (4800) mark masung Inc
on arduino ide if we use e.g ;
Serial.print(0x1B,0x69);
or something else with print is just print it on the paper not other thing do
what exactly the command necessary for do order with UART interface not just send text
on the document technic i find those line
2.7.1 Transmit command (sending )
[interface]
int PrintTransmit(const char* bCmd,int iLength)
[function]
Transmit original command to printer
[parameter]
name
type
parameter description
bCmd
char*
command
iLength
int
command length
[return value]
0 success
1 failure
[sample]
char bCmd[2]={0x1B,0x69}; //cutting command
int r = PrintTransmit(bCmd,2);
The SDK reference manual seems to detail the high level function calls that you woukd use on Win or Linux. You need the document that details the low level instructions that the printer understands.
You may be lucky in that the seller has rebadged another manufacturers printer. You would probably need to look for some identifying model number on one of the internal boards.
It's not clear from the document whether the PrintTransmit function applies additional bytes to the command or not. You could be missing an escape sequence.
Mechanism: MS628MCL101
Printing method Thermal dot line printing
Dots/line 384 dots/line
Dot pitch 8 dot/mm
Paper width 58 mm
Printing width 48 mm
Paper thickness 54~78 um
Printing speed 100 mm/s
Paper feed direction 180° horizontal
Sensors Head temperature Thermistor
Paper press shaft Mechanical switch
Paper end Photo interrupter
Paper loading Easy loading
Font size ASCII:9*17;12*24;
Chinese: 24*24
Power supply Logic circuit 2.6~3.6 V
Motor 4.75 ~9.5 V
Dimension (L*W*H) 180.7*102*101.5 mm (with 80mm diameter paper roll)
Weight Approx 0.45 kg
Reliability Circuit: over 1,000,000,000 pulses
Cutter: over 7,000,000 cuts
Thermal head: over 100 km
MCBF: 37,000,000 lines
Ambient environment Work temperature 0 ℃~50℃
Work humidity 20~85% RH
Storage temperature -20℃~60℃
Storage humidity 10~90% RH
Weight 450 g
Interface RS-232/TTL/USB
power supply DC 12~24V/2.5A
Command set ESC/POS
Barcode supported
Firmware location 2 M NV Flash memory
Buffer 4 KB
SRAM 20 KB
System Windows/Android/Linux
Accessories: paper near end sensor;
Paper holding unit;
Paper bezel (paper guide mouth)
Interface connector
Power supply unit
Cable
its clear that line ( RS-232 / TTL / USB ) for TTL
i dont know what meaning this secret about those type of product i dont find any other information about this printer
his sitweb is
