How i can use this eeprom?
i have one machine contain those type of eeprom (S93C56BD && S93C86BD) and i need to receive every data send to it and show it in serial monitor
this type i tink no have address protocol like 24Cxx
i try i2c scanner and i2c snupper with no successes
what i do about that please :pray::pray:
those datasheets of eeproms
IS93C76A.pdf (301.5 KB)
S93C56B.pdf (505.4 KB)
Did you try SPI?
no im not try it how i can do scanner of SPI
Those chips use the Microwire interface. Arduino library here: GitHub - tim0s/MicrowireEEPROM: Read and write EEPROMs using the Microwire protocol, such as the ST93C66
my be is it it contained sc sk di do of his pinout
thinks you so much it is i need more help for that
how i can read the information send it to this eeprom in storing time and show it in serial monitor
You will need to carefully study the library example and the EEPROM data sheet. Also, search the web for "microwire eeprom arduino" to find more information.
think you i wi do that
