how i get from user in Serial number and after a string or char?
i need send to func a char and number to turn on a.c by heat/cold and temp number
like (heat,28)
and the a.c is turn on heat on 28
i try to get a number and char but is get only the number
help =\
AC();
void AC()
  int x;
  Serial.println("Type a temp (18-30) into the box above,");
  while(true)
    while (Serial.available() > 0)
      x = Serial.parseInt();
      x = constrain(x, 18, 30);
      Serial.print("Setting temp to ");
      Serial.println(x);
      Serial.print("Input char : ");
      char c=Serial.read();
      Serial.print("the char is : ");
      Serial.println(c);
You may try func('h', 28) where 'h' is just a single a char that your func() will interpret as meaning "heat". If you want to pass a string, as in func("heat", 28) you'll have to use strcmp() to check the value of the string.
tnx for answer ,
i try to get a char and int , look at the code, the int is good but after i want to get a char is skip the command
I see. Well that happens because
     Serial.print("Input char : "); // there is not enough time from print() to read()
     char c=Serial.read();          // so serial.read() will get -1
You may change into:
     while (!Serial.available()) {}  // do nothing until there is a character to read()
tnx !!
