How is a circle appeared when the Piezo sensor is moved?
I trie to write a code like this, but it does not work.
import processing.serial.*;
import org.firmata.; import cc.arduino.;
Arduino arduino;
int S1 = 0; int A; void setup() { size(500, 500); ellipseMode(CENTER);
arduino = new Arduino(this, Arduino.list()[0], 57600);
arduino.pinMode(S1, Arduino.INPUT); }
void draw() {
A = arduino.analogRead(S1); println(A); if (A ==1) { ellipse(width/2,height/2,100,100); } }
It looks like the circle should appear if the analog input read from pin A0 is exactly 1. That would be about 4.883 millivolts.
Pinset is also right.
papa1963: Pinset is also right.
No idea that you are asking/saying here.
You have defined the pin to be a digital input pin, but are reading from it as though it was an analog pin.
try
void draw() {
  println(A);
  if (A >=1) {
analogRead can give you a value between 0 ~ 1024
what is displayed with the println(A);
@papa1963: Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Your other two, almost identical, threads deleted.
  • Moderator
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
Please use code tags.
Read this before posting a programming question
How to use this forum
