I have a "store bought" LED strip that is in an unusual configuration. It has a single strip about 4 feet long and one end has the connection for a controller. The other end terminates in a round disk with 9 equally spaced connectors laid out so that 9 separate 18 inch strips radiate outward like spokes in a wagon wheel.
I'd like to figure out how all the led on the "spokes" can be addressed 1 by 1. Anyone know how to do this??
Thanks much
Stripper (not what you're thinking; it's because I work with LED STRIPS!!)
You're kidding right?? Most ALL strips come from China and if there happens to instructions included, they are basically unusable do to their pathetic attempt to read/write in English.
Now I know based upon the negative comment I just made, what your response is likely to be??
There is more than one protocol, but all addressable LED strips seem to be serial... The data passes-through all of the LEDs/drivers and when it stops that's what you get.
The most popular strip seems to be the WS2812 (AKA Neopixels). These use just one "data" connection (plus power & ground) and the pulse-timing determines when you're addressing the next LED. The timing is tricky so there are software libraries to help.
There are other LED strips that have separate data & clock lines, so the coding is simpler.
If you buy a "basic" LED strip from a reliable supplier they should give you a link to the datasheet & specs, and Adafruit has libraries you can download and all kinds of helpful information.
If you buy an assembled ready-to-go display and controller of course they don't have to give you any details and it might be impossible to "hack".
