How is double represented on arduino?
I wanted to see how arduino represents doubles so I could send them over serial port, so I tried
Serial.begin();
double x = 58.285;
for (int i = 0; i < 8; i++){
   Serial.println((unsigned char)*((char*)&x+i));
which prints out
215
35
105
66
0
52
0
91
but no matter how I arrange these bytes, I never get the original number. For getting the original number I used in rust
f64::from_le_bytes([215, 35, 105, 66, 0, 52, 0, 91]);
with some permutations of numbers. For float it works fine without even need to rearrange it, so what's the problem with double?
Try using sizeof to see how big that double actually is.
8 bit or 32 bit Arduino ?
on a 8 bit a double is really just a float (single precision)
on a 32 bit microcontroller then you get 8 bytes and a "real" double
On most arduino's double is not actually implemented, but will use float instead.
Thanks a lot, I never considered an option that it is just a float. When I tried that, it worked perfectly.
