how is the tilt Switch work ?
when I start learning simple electronics with the Arduino starter kit :slight_smile: there are a component that can not understand
It's the tilt switch first of All I want to know how it works and why we use it and what every leg from the four legs do ?
It may be used to see if something is the right way up.
(For a simple project where you want to throw a disc and see which way it has fallen)
When the Up side is UP then all the contacts are connected together.
When it is up side is facing down then all the contacts are open. (No connection between any pins)
There is a small piece of metal that physically slides to the other side when you flip the sensor.
It acts as a simple mechanical switch which close when the UP is facing up, and switch opens when the Up side is facing down.
sh_aks:
can you please give me a tow PICs on the Breadboard when Up face the Up and when the Up facing down
cause I can not imagine it :slight_smile:
