I have to make some of my servo cables longer. Currently its 12 inches long. How long of a run can you do before you lose performance, Powering off usb, Is there any way to gain back any loses, with out switch from using usb.
I need another 12 Inches (Maybe more if I can). Gonna probably use this for wire: http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=Hook+Up+Wire&product=2780757
Just because its kicking around. But I think the gauge of 24 might be a bit low. Is stranded better then solid for current? Have some of that too, Same gauge (24).
Not going to go and buy some fancy cable with proper ends, and worry about them disconnecting, getting worn out. Just gonna cut and solder.
Here's my servo: http://www.hitecrcd.com/servos/show?name=HS-311
And my board: http://www.solarbotics.com/products/28920/
