I'm having a problem on arduino serial communication. I need to establish multi drop serial network for about 300 - 400 meters. Is it possible to use MAX485 with twisted pair lines?
I am confused as am newbie in this regards.
If it's not possible, please suggest me a reliable way...
your help is highly appreciated.
Is it possible to cover that distance when we use MAX485 since it works in 5V?
yes, as long as you wire it as a bus with short stub lengths, and terminate each end of the bus.
Basically you need 3 wires, A,B, and GND. I have used CAT5 with no issues. I use 4 pair CAT5e 1,2=A,B 4,5=GND, 3,6=second Channel A,B 7,8=remote Power +12v.
I use 120 ohm terminators at each end of the link, I wire it with one set of pullups/pulldowns 680ohm as a fail safe configuration:
+5v<->680ohm<->A<->120ohm<->B<->680ohm<->GND at the Master end,
A<->120ohm<->B at the end Slave.
My RS485 devices use 2 RJ45 sockets, one in, one out. this makes my stub length less than 1 inch(from Socket to MAX485 or SN75176) for each device. each device has a jumper selectable termination. Only the Master and Last Slave have the termination enabled. This allows me to use standard CAT5E patch cables. (EIA/TIA 568B wiring). As long as I don't plug my RS485 network into a 1gb Ethernet port every thing is happy :). Standard 10,100mb ethernet only use 1,2,3,6
As a secondary ground fault protection I place a 100 ohm resistor between 4,5 and my device ground to limit ground loop fault currents.
