When i write something basic in the software (e.g counter with led display), and i want to change the script (e.g. Changer the delay), how long does it take to compile the program transfer it to the board and run it?
Arduino relies on an "out of process" compiler. Arduino IDE has to start a seperate program to compile the program.
The transfer to the Atmega processors flash memory takes place over a slow serial connection.
But remember that once the program is in the flash memory it remains, surviving powercycling the Atmega processor, so it is only if you need to make changes in your program it matters.
since we are on a similar topic, il just ask this here:
besides just uploading the code to the i/o board... which is what i have done since the first day i got the arduino (like 2 weeks ago), wat does it mean to "burn bootloader" using whatever the different choices are?
It almost sounded like you wanted to recompile and upload just to change process values in your application. Normally you would just set up communications via serial port, and the change in process value would now be instant.
The bootloader is the piece of firmware that programs the rest of the microcontroller over the serial port. Without it, you would need special hardware to write new code into the Arduino.
When I was a lad, it took 15 minutes just to compile a program
At the risk of being Pyhtonesque .... Luxury
When I started programming you could submit your punched cards once a day. Imagen learning to program only being able to type RUN once a day and not at weekends.
I've often said that my typing skills are so bad, I'd be doing something else for a living if I had to deal with punch cards in school. Fortunately the last punch card machine was gone shortly before I started.
We did have to use line-mode editing, though. Full screen capable terminals were for faculty and staff. (:
