how make a memory to handle a car mirror when reverse gear?
Hi all, first of all I am new to this forum. I am jose, I'm from Spain jaen. forgive me my English. I would like to make a memory with arduino, when I engage reverse gear of the car, the lower right rear view mirror to see the wheels when parking. And disengaging reverse gear is positioned in the place that was. it's possible?
I put the same text in Spanish if it is better understood thanks
Hola a todos, en primer lugar soy nuevo en este foro. Soy José, soy de España Jaen. perdóname mi Inglés. Me gustaría hacer una memoria con Arduino, para cuando la engrane marcha atrás del coche, el espejo derecho baje hacia abajo para ver las ruedas al aparcar. Y desacoplar la marcha atrás que vuelva donde estaba desde un principio. ¿Es posible?
The first step will be to figure out how to run the positioning motors in the passenger side mirror. Do you have the circuit diagram? How many wires to each motor? Is there any feedback mechanism?
Did you see the Spanish section of the forum?
Before attacking the motors, how do you control the mirror positions right now?
When there are physical switches, you can let an Arduino press the switches for you, using some hardware.
And yes, position feedback is a critical item. When your switches go directly to the motors, no feedback may be available, i.e. you won't know the current position of the mirror, and how long to run the motors in which direction. When a controller is already handling the mirror positioning, you have to figure out how to communicate with that controller (CAN bus?), i.e. how to make it move to the intended position, and how to get back the current positions.
