How make pwm frequency 50hz( pin num : 3, 5, 6, 9, 10)
help...I want to make pwm frequency 50hz( pin num : 3, 5, 6, 9, 10)
i need pwm output 50hz.
but i cant understand
so i need help..
please answer my question
50Hz is pretty slow. Use blink without delay
/* sketch to output 20KHz signal
 run on regular Arduino
byte pulseOut = 2;
unsigned long currentMicros;
unsigned long nextMicros;
unsigned long duration = 25UL; // flip every 50uS = 20KHz pulse
// increase for slower pulses
unsigned long elapsedMicros;
void setup(){
  pinMode (pulseOut, OUTPUT);
  digitalWrite(pulseOut, LOW);
void loop(){
  currentMicros = micros();
  elapsedMicros = currentMicros - nextMicros;
  if (elapsedMicros >= duration){
    nextMicros = nextMicros + duration;
    PIND = PIND | 0b00000100; // toggle D2 by writing to Input register
There's enough info in that sheet to do what you need. Im' pretty new to this, but the salient things seem to be:
  • It's specific to arduino mega. I don't know how the different board differ (the whole point of the libraries is to hide that stuff from the programmer)
  • The pmw register steps at the clock frequency divided by a power of 2
  • the register steps from 0-255, but you can clip that
  • you can set a value at which the modulation turns on and off
Now, if your chip is 16mz, that's 0x4e200 chip cycles per output cycle (16000000/50). let's divide this by 1024 to get 0x138. Now, this is greater than 255, whic is a problem. But the PWM thingy can be set to scan up and then down (phase-correct mode). So divide 0x138 by 2 to get 0x9c. Yay!
  • set the cycle divider to 1024
  • set the PWM to phase-correct mode
  • use 0x9C (or possibly 0x9C-1, depending on how it works) as the upper bound
  • use "Toggle OCnA on Compare Match" to give you a fixed 50% duty cycle.
You will have to fiddle a bit to get it right, but by my reading of the document you linked to, this will get you in the ballpark.
You could do it in hardware on a Mega with Timers 2,3, and 4 but you need a close read of the data sheet to set them up. If you are on a UNO, pins 5 and 6 are on Timer 0 which is the system millis() timer, and I wouldn't recommend changing its prescaler unless you are sure of what you are doing and can sort out any unintended consequences.
I would recommend using Crossroad's approach of toggling the pins using a software timer with micros() rather than the hardware timers.
