How many Leds can control
Hi.
I want to build a led wal with ws2812b leds controlled by an arduino Mega
with this code
#define PIN            11
#define NUMPIXELS      32
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int v1 = 0;
int v2 = 0;
int v3 = 0;
int v4 = 0;
   pixels.begin();
void loop(void) {
  if (Serial.available() > 3) {
      v1 = Serial.read();
      v2 = Serial.read();
      v3 = Serial.read();
      v4 = Serial.read();
       pixels.setPixelColor(v1, pixels.Color(v2,v3,v4));
       pixels.show();
Is there a limit on how many can be controled ?
Thanks
Yes.
The amount of RAM you have.
Memory
An Arduino Uno has 2kb of memory. One Neopixel led uses 3 bytes of memory. That means you can drive about 600 Neopixels, or a bit less, depending on the size of the rest of your program.
Ref:https://www.eerkmans.nl/powering-lots-of-leds-from-arduino/
RV mineirin
With the posted code, you can control 32 pixels.
It's a little more convoluted but you can control a lot more than you have RAM for if you are using a repeating pattern or a very simple/predicable pattern
What kind of pattern do you want to use?
Thank for the answers.
I know that code is for 32
I will use arduino mega2560 so x4 ram than uno
Thats 2400. Right?
I will control it with serial data coming from PC. Any pattern Possible
