Because I'm a relative noob I tend to just hit auto-route in Eagle and hope for the best ... but often I find myself in the situation where something that works on breadboard just falls over with an auto-routed board.
How could it get it wrong though? Surely it's just following one's schematic?
There are some things on a PCB that are critical and must be routed carefully (clock traces, decoupling capacitors for example) while others don't matter much and can be autorouted.
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
It's not a matter of trusting the autorouter not to be "correct", but....
I don't trust the autorouter to understand things that I haven't told it, such as which signals have higher currents, and which are more critical to have short traces, and which traces it would be nice to have some ground plane in-between. (Some of this you can tell it via "class", some not.)
I don't trust it to create "conservative" routes. For example, it will "hug" traces as close to other traces/pins/etc as the design rules and routing grid allow, whereas I would put traces as far apart from everything as possible.
It doesn't know how to temporarily narrow traces for power when the trace should be thick otherwise.
It doesn't know about curves (?) or bends other than 45 degrees. Sometimes this is OK, sometimes very limiting.
I don't trust it to warn me if some signal ends up traveling all over the board
I don't trust it to produce a particularly "optimal" design.
I don't trust it to finish designs that are possible but difficult.
I don't expect it to give me any advice like "gee, it would work better if THIS chip was over THERE."
I don't trust it to produce an esthetically pleasing design.
I frequently use the autorouter as a starting point. Sometimes it's good enough. And if it fully routes the board, at least I know that it is possible!
That too. Position parts and autoroute till it looks reasonable. Then rip up everything, manually route anything critical, and autoroute again to fill in the less critical pieces. Then clean up the ugly bits.
Careful, you can't "undo" an autoroute and get back to a partially routed board. Save the file before running autoroute, and you can revert if it's too unpleasant.
I've had luck with Eagle doing an initial placement, seeing where autorouting failed, ripping up & moving parts, letting it route again. Saves a lot of time on fixing clearance issues and drill size errors and trace width problems.
Then go back and look for unreasonable traces and shorten them up.
Eagle seems to have the worst time at the end getting all the ground connections done. My recent designs, duemilanove size with more components added & bigger processors (1284), I've had to move signals around to expand ground plane areas and then add vias to connect them so all pins had access to ground where needed.
And one of them, the autorouter just couldn't do it, way too many unconnected signals, gave up & did it all by hand.
The thing that gets me is cleaning up clearance issues on the autorouted signals!
I enjoy the puzzle of tweaking signal placement to maximize ground polygon coverage (often leading to cleaning up clearance issues I created (: ).
Hardest part is managing to close the polyon in the corner I start it at. Am usually zoomed out enough to see all the corners of the board, makes the starting point hard to see. Just takes some practice I guess.
I always put my pour polygons well outside the board outlines, not exactly overlapping each other, and on a larger grid. It makes them much easier to draw and fiddle with...
westfw:
Good tip! I had to click and pick them up every time I re-size my board. I'll do it your way starting next board.
Maybe the OP can share a design or two that worked on a breadboard but failed on a PCB so we can see what went wrong, the auto router or something else.
