How many pins of the Arduino Micro are really useable as digital I/O pins?
Hi folks!
I’ve recently acquired an Arduino Micro and I’m confused by the number of I/O pins stated on the website (20 pins) vs. what I’m able to see in the schematics and pin-out diagram (24 pins). Are the MOSI, SS, MISO and SCK-pins not useable for digital I/O?
Nothing in the datasheet hints in that direction and the pins_arduino.h file makes them useable for digtalWrite/Read etc. too and counts D23…0:
// Map SPI port to 'new' pins D14..D17
static const uint8_t SS   = 17;
static const uint8_t MOSI = 16;
static const uint8_t MISO = 14;
static const uint8_t SCK  = 15;
// On the Arduino board, digital pins are also used
// for the analog output (software PWM).  Analog input
// pins are a separate set.
// ATMEL ATMEGA32U4 / ARDUINO LEONARDO
// D0				PD2					RXD1/INT2
// D1				PD3					TXD1/INT3
// D2				PD1		SDA			SDA/INT1
// D3#				PD0		PWM8/SCL	OC0B/SCL/INT0
// D4		A6		PD4					ADC8
// D5#				PC6		???			OC3A/#OC4A
// D6#		A7		PD7		FastPWM		#OC4D/ADC10
// D7				PE6					INT6/AIN0
// D8		A8		PB4					ADC11/PCINT4
// D9#		A9		PB5		PWM16		OC1A/#OC4B/ADC12/PCINT5
// D10#		A10		PB6		PWM16		OC1B/0c4B/ADC13/PCINT6
// D11#				PB7		PWM8/16		0C0A/OC1C/#RTS/PCINT7
// D12		A11		PD6					T1/#OC4D/ADC9
// D13#				PC7		PWM10		CLK0/OC4A
// A0		D18		PF7					ADC7
// A1		D19		PF6					ADC6
// A2		D20 	PF5					ADC5
// A3		D21 	PF4					ADC4
// A4		D22		PF1					ADC1
// A5		D23 	PF0					ADC0
// New pins D14..D17 to map SPI port to digital pins
// MISO		D14		PB3					MISO,PCINT3
// SCK		D15		PB1					SCK,PCINT1
// MOSI		D16		PB2					MOSI,PCINT2
// SS		D17		PB0					RXLED,SS/PCINT0
Ahhh, I just noticed that the Leonardo – unlike the Micro – doesn’t lead the MISO, MOSI, SS and SCK pins to the outside (except for the ICSP-header). So probably just a simple copy&paste mistake in the description page?
Do you know what those abbreviations mean ?
No .it's not. they are on the ISCP 6-pin header on the end of the board opposite the end with the USB.
first off, are you talking official micro?
you can get a board labeled micro, nano or mini on e-bay and all get the exact same board. and not one having the pin-out that matches the official version.
google arduino micro and look at the official data sheet.
if your board does not look like that, exactly like that, then your 'clone' may be different and probably is.
that official data sheet will give you a clue to what you can do.
if your board is not an official board, then google arduino micro pin out and see what you might have.
as raschemmel pointed out, pins on the board may be connected to other pins. just because there is a separate connector does not mean is is a separate circuit.
raschemmel:
Yes, they are for SPI. But I can’t find anything in the ATMega32U4’s datasheet telling me I can’t use them as simple digital I/Os. The SPI functions are just listed as „Alternate Functions of Port B“ in the I/O Chapter.
Yes.
Edit: Using an external programmer would restrict the use of those pins of course.
@Mike1,
What I mean is that if you know about SPI then you know those labels are irrelevant unless you included the SPI library in the sketch. Otherwise, they are just digital pins like any others. The flip side of that coin is you can't use them for anything else when
you're running a SPI app. Pin 10 is sometime s an SD chip select and it has to be reassigned if your using SPI.
