How many samples can a photo interrupter take per second?
I am going to use a photo interrupter to sense linear distance. I would like to be able to plot 300 different distance readings within the time span of a second. If you would like to know more about my project I can explain if you are interested..but my main question is; Is a photo interrupter capable of giving 300 samples per second?
Where can I find this when analyzing the datasheet of a photo interrupter?
I understand you get what you pay for...but I was wondering if one like this one would work; https://www.sparkfun.com/datasheets/Components/GP1A57HRJ00F.pdf
On the datasheet I found the table below, this may sound silly but is the time needed per sample really just all the max response times added together?
Almost always substantially less than that total. A better upper estimate would be to add the "typical" times together.
In any case, 300 samples/second is VERY slow on that time scale.
Thank you very much
How are you getting distance from that? It just lets you detect that something is between the LED and the detector.
Agreed, that is not a "linear distance sensor".
See Pololu for the genuine article. They are much slower that an optointerrupter.
