How many shields can you use at the same time with Arduino Uno R3?
How many shield can you use at the same time?
Thanks!
This depends on if the shields are stackable and what IO pins are used.
Different shields may use fixed pins so if you stack two of them, you cannot run two shields with the same outputs.
Weedpharma
So long as you have no pin conflicts and don't over-load the power supply(s) then you will be OK.
So I guess it's generally not possible to configure the shields to use specific pins?
Depends on the shield.
A prototyping shield allows any pin to be used.
Some such as the Ethernet shield I have uses fixed pins.
Weedpharma
Davidrules: How many shield can you use at the same time?
68.
sixty-eight?
How do you know that number? O_o
Maybe even 71 It depends how long your string is.
Grumpy_Mike: 68.
You can connect 69 if the top one is round the other way. :wink:
Davidrules: sixty-eight?
Google "taking the piss"
Weedpharma
You can use Serial-in, Serial-out and Sync-clock many times. So number of shields depends on the other pins used , as long as no pin is used twice then it will work.
weedpharma: Google "taking the piss"
+1 ;)
