How many thermocouples can I attach to Arduino UNO R3 ?
Hi
I am currently busy with a engineering project that requires object surfaces to be kept at constant temperatures inside a wind tunnel. The inside object will contain heating elements and on the outside a thermocouple would be connected.
My idea so far:
The heating element (connected to a relay) should turn on and off depending on the reading the thermocouple obtains.
I am planning to use a MAX31855 thermocouple to digital converter and then a K-type thermocouple.
I need to control the temperatures of a few surfaces (probably 5 ) and would like to know how many surfaces i would be able to control with one arduino board
Thank you
The Adafruit MAX31855 board requires three digital pins (CS, CLK,DO) and you'd need another for a relay to switch on your heating, so four per thermocouple. An Uno has 20 pins available for use as digital I/O, so you could control five surfaces with one.
That would mean that you would have given up use of the serial port for debugging, which would not be desirable.
I suspect though that you could share CS and CLK and if so, the Uno has a more than enough pins available for five surfaces and some debug.
CLK and DO can be shared by all the thermocouple interfaces. CS needs to be separate per thermocouple.
See:
http://arduino-info.wikispaces.com/Brick-Temperature-Thermocouple#TC2
Two Thermocouples to LCD Display
This shows two MAX6675 modules connected to a RoboRED (UNO compatible). A terminal strip has been used to connect the Vcc, GND, CK and SO wires together. There are separate CS (Chip select) wires so the two thermocouples can be read separately.
