How many ways can you get something wrong? :)
I've just been building a breadboard circuit with an LD1117 3.3v regulator.
I have the datasheet in front of me. It has 3 pins - left to right they are GND, OUT, IN.
I must have tried every possible wrong combination before I got it working!
Old age, I suppose.
Just as well the device is robust!
...R
;D
I did some advanced calculus and computer modeling and concluded that there are 6 possible ways to arrange 3 items. :slight_smile:
But if you think that’s bad, I more often than not need two attempts to plug in USB cables. That’s a fail with only 2 possible ways. If I don’t look at the socket and the plug first to figure out which way it goes in, and decided to brute force algorithm it by just trial and error, I literally get it wrong on the first attempt more than 50% of the time. I just have rotten luck.
INTP:
If I don't look at the socket and the plug first to figure out which way it goes in
The raised USB symbol is always on the top of the connector. :wink:
It's well known that USB cables always need three attempts before they plug in.
:slight_smile:
Graynomad:
Man, that is true more times than I'd like to admit. Especially with micro-USB plugs like for a phone. First orientation was correct, but it snags or doesn't go in for some reason, flip it around, still doesn't go in, have to give it a third go in the secret third option. :confused:
INTP:
try plugging it in sideways?
It's a USB port, not a woman.
I forget who but someone named it the Quantum USB Superposition Theorem. Basically the socket can be incorrect both ways at once.
[quote author=Coding Badly date=1469999719 link=msg=2864108]
The raised USB symbol is always on the top of the connector. :wink: [/quote]
Not much use if your computer has the sockets upside down, as one of mine does.
Robin2:
I’ve just been building a breadboard circuit with an LD1117 3.3v regulator.
Old age, I suppose.
…R
Watching those things burn up when you hook 12v to a 6v MAX regulator is kinda fun… The first one just smoked a little, the second one turned into a ball of flames. Then i decided to take a gander at the data sheet.
I’m out about 30 bucks… (two esp8266, two PCBs, and capacitors/resistors);
Hey Robin, I have come to assume that whichever way I try some binary(ish) thing will be the wrong choice the first time. I can take ths into account, but then the rules change (by spooky action) and the way I was going to do it was right, so if I change, it will still be the wrong way.
Usb cables are just the beginning. The worst for me is password/username combinations. They usually give you three tries at a login until locking you out. However, there are four combinations of two usernames and two passwords.
almost all of my desktops have vertical USB sockets...
ChrisTenone:
Yeah - I think that nails it :slight_smile:
...R
No matter how many times I look I always manage to line the 9pin DIL com-port plug the wrong way up.
My excuse, it doesn't have an UP /TOP arrow.
Tom... :slight_smile:
