How minimize code that signal from oscilloscope to pin 8,9 on arduino uno?
How to minimize the code below? The code that I'm used is:
int data=8, clk=9;
  pinMode(data, OUTPUT);
  pinMode(clk, OUTPUT);
  digitalWrite(data,HIGH);
  digitalWrite(clk, HIGH);//1
    delay(10);
    digitalWrite(clk,LOW);
    delay(10);
 digitalWrite(data,LOW);
  digitalWrite(clk, HIGH);//2
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//3
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//4
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//5
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//6
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//7
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
  digitalWrite(clk, HIGH);//8
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
Well you could save some typing by creating a function to output a sequence of X empty clock cycles. However, if you give more details of your task, there may be a better general solution.
in order to find the SCl and SDA of FD616 that controls address of 7 segment display I'm using the oscilloscope to see if the SCl and SDA can be sent back to FD616 .
What is a FD616?
Can you please post a link to specs/data of the FD616?
What model Arduino are you using?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
have you tried using an I2C scanner?
google
 i2c scanner arduino
a7
FD616_DATASHEET_A3.pdf (1.8 MB)
yes
Do you have an English version?
Manufacturers description.
[ ] From the English text in the data sheet it appears to be an I2C seven segment display driver chip.
[ ] You will have extreme difficulty simply attempting to simulate the I2C protocol, by explicit manipulation of the pins, and get some visible results on that chip.
[ ] One approach is to use I2C on the arduino to communicate with the chip using the dedicated arduino I2C pins and watch the data stream using the oscilloscope.
[ ] If you then must, for the purposes of your exercise, send simulated or hand crafted I2C using digitalWrite(), you have an example to follow. However, I2C is a 2 way protocol so you may not get very far.
arduino due
