How much free memory ?
Is there a simple way I can get the amount of free memory using a library call ?
Andy
http://www.arduino.cc/playground/Code/AvailableMemory
Is a start.
Thanks,
just what I needed !
Andy
:frowning:
Why the face, Mike?
Honestly, it's like living with teenagers around here, sometimes :smiley:
I agree… >:( … none of the above are good solutions.
Here is my solution, which is based on the code in malloc.c that checks for enough available memory. This is from the AVR-LIBC 1.6.6 distribution but may well work with earlier versions if the code hasn’t changed.
#include <stdlib.h>
#include <inttypes.h>
#include <avr/io.h>
extern char * const __brkval;
uint16_t freeMem(void)
  char *brkval;
  char *cp;
  brkval = __brkval;
  if (brkval == 0) {
    brkval = __malloc_heap_start;
  cp = __malloc_heap_end;
  if (cp == 0) {
    cp = ((char *)AVR_STACK_POINTER_REG) - __malloc_margin;
  if (cp <= brkval) return 0;
  return cp - brkval;
Thanks for the better code. I really only needed a function for debugging, checking for memory leaks.
But thanks again all.
Andy
