I am trying to workout how much sram I have left using :-
int availableMemory() {
int size = 1024;
byte *buf;
while ((buf = (byte *) malloc(--size)) == NULL);
free(buf);
return size;
it says 388 bytes left !!!
My variables should only use around 98 bytes.
4+9+9+2+2+14+3+18+18+1+4+2+2+1=98 byte
Where is my sram going ?, and how can ? can I change my code to reduce this.
#include <Wire.h>
long clock_delay = 0;
char bcd_string[]="12:34:56";
char clock_string[]="??:??:??";
int rtc_address = B1101000;
int io_address = B100001;
int rtc_bcd[7];
boolean alarm_set[3];
int alarm_on[3][3];
int alarm_off[3][3];
boolean knight_run = false;
long knight_time = 0;
int knight_delay = 30;
int x = 0;
boolean forward = true;
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
// start_ball(); // set the rtc arrary , not needed now I have a battery
// clock_save();
int_alarm();
// alarm_set[0] = true;
set_alarm(0 , true , "22:20:00");
set_alarm(0 , false , "22:25:00");
alarm_set[1] = true;
set_alarm(1 , true , "00:55:00");
set_alarm(1 , false , "00:57:00");
// alarm_set[2] = true;
set_alarm(2 , true , "12:00:00");
set_alarm(2 , false , "12:00:01");
display_alarms(0);display_alarms(1);display_alarms(2);
io_int();
Serial.print ("Bytes of available Memory = ");
Serial.println (availableMemory(), DEC);
clock_read();
bcd2string();
if (strcmp(bcd_string , clock_string) != 0)
// Serial.println(clock_string);
strcpy(clock_string , bcd_string);
check_alarms();
if ( millis() >= knight_time )
knight_time = millis() + knight_delay;
if ( knight_run == true ) knight();
} // end of loop
void clock_save()
Wire.beginTransmission(rtc_address); Wire.send(0x00); // reset register pointer
for(int i=0; i<7; i++) { Wire.send(rtc_bcd*);} Wire.endTransmission();*
void clock_read()
- Wire.beginTransmission(rtc_address);*
- Wire.send(0x00); Wire.endTransmission(); Wire.requestFrom(rtc_address, 7);*
for(int i=0; i<7; i++) { rtc_bcd*=Wire.receive();}
_}_
void start_ball()
_{_
rtc_bcd[0]=B00000000; // Second -- 0 --
rtc_bcd[1]=B01000101; // Minites -- 45 --
rtc_bcd[2]=B00001010; // Hours -- 2 --
rtc_bcd[3]=B00000001; // Sunday 1 , Monday 2 , Tuesday 3 etc in BCD -- Saturday -- 7 --
rtc_bcd[4]=B00000001; // Date -- 1 --
rtc_bcd[5]=B00000001; // Month -- 1 --
rtc_bcd[6]=B00000001; // Year -- 1 --
} // end of start_ball*
void string2bcd()
* rtc_bcd[2] = (bcd_string[1]-48) + (bcd_string[0]-48 << 4); //hours 12:12:12*
* rtc_bcd[1] = (bcd_string[4]-48) + (bcd_string[3]-48 << 4); //mins*
* rtc_bcd[0] = (bcd_string[7]-48) + (bcd_string[6]-48 << 4); //sec*
} // end of string2bcd
void bcd2string()
* int rtc_dec = 0 ;int j = 0 ;int i = 2 ;
rtc_dec = (( rtc_bcd & B0111000) >> 4) * 10 + (rtc_bcd & B00001111); // hours 2 , mins 1 , sec 0
if ( rtc_dec <= 10 ) bcd_string[j] = 48;
bcd_string[j]=(rtc_dec / 10 )+48;
j++,bcd_string[j]=(rtc_dec % 10)+48,j++,bcd_string[j] = 58,i--, j++ ;
rtc_dec = (( rtc_bcd & B1111000) >> 4) * 10 + (rtc_bcd & B00001111); // hours 2 , mins 1 , sec 0
bcd_string[j] = (rtc_dec / 10 )+48;j++;bcd_string[j]=(rtc_dec % 10)+48;j++;bcd_string[j] = 58,i--, j++ ;
_} // end of bcd2string*
* int size = 1024;
byte buf;
while ((buf = (byte ) malloc(--size)) == NULL);
free(buf);
return size;
void int_alarm()
{_
strcpy(bcd_string , "12:00:00");
_ string2bcd();
for(int j=0; j<3; j++) {
for(int i=0; i<3; i++) {_
alarm_on[j] = rtc_bcd;
alarm_off[j] = rtc_bcd;
} alarm_set[j] = false; }
} // end of int_alarm*
void display_alarms(int j) // 0 1 2
{ for(int i=0; i<3; i++) rtc_bcd = alarm_on*[j];
_ Serial.print("Alarm "),Serial.print(j,DEC);_
if ( alarm_set[j] == true ) { Serial.print(" - on - "); } else { Serial.print(" - off - "); }
_ Serial.print("Alarm on time ");_
bcd2string(),Serial.print(bcd_string);
for(int i=0; i<3; i++) rtc_bcd = alarm_off[j];
_ Serial.print(" - Alarm off time ");_
bcd2string(),Serial.println(bcd_string);
} // end of display_alarm*
void check_alarms()
* { clock_read(); bcd2string(); strcpy(clock_string , bcd_string);
_ for(int j=0; j<3; j++)_
{ if ( alarm_set[j] == true ) {
for(int i=0; i<3; i++) { rtc_bcd = alarm_on[j] ; }
_ bcd2string();_
if (strcmp ( bcd_string , clock_string ) == 0) alarm_trigger_on(j);
for(int i=0; i<3; i++) { rtc_bcd = alarm_off[j] ; }
_ bcd2string();_
if (strcmp ( bcd_string , clock_string ) == 0) alarm_trigger_off(j);
}}} //end of check_alarm*
void set_alarm(int alarm , boolean on_alarm , char alarm_time[] )
* { strcpy(bcd_string , alarm_time); string2bcd();
_ for(int i=0; i<3; i++)_
{ if ( on_alarm == true ) { alarm_on[alarm] = rtc_bcd;
} else { alarm_off[alarm] = rtc_bcd;
}} }// alarm_set[alarm] = true; } // end of set_alarm*
void alarm_trigger_on(int alarm)
{ switch (alarm) {
* case 0:*
* //do something when var == 1*
* break;*
* // break is optional*
* case 1:*
* //do something when var == 2*
* knight_run = true;
_ break;
case 2:
* break;
void alarm_trigger_off(int alarm)
{ switch (alarm) {
case 0:
* break;
* case 1:
* knight_run = false;*
* break;
case 2:
* break;
void io_int()
do { _
x = read_io(6),write_io(6,0);
_ } while ( x != 0 );
do {_
x = read_io(6),write_io(6,255);
_ } while ( x != 255 );
do {_
x = read_io(6);
write_io(6,0),write_io(7,0);
_ } while ( x != 0 );_
write_io(0,1),write_io(1,0);
} // end of int_io*
int read_io(int cmd_reg)
*int tmp; *
Wire.beginTransmission(io_address);
Wire.send(cmd_reg); // 0 or 1 -- GP0 or GP1
Wire.requestFrom(io_address, 1);
tmp=Wire.receive();
return tmp;
} // end of read_io
void write_io(int cmd_reg, int push_this)
* Wire.beginTransmission(io_address);
Wire.send(cmd_reg),Wire.send(push_this); // reset register pointer then set GP0 to push_this // use (0,??)
_ Wire.endTransmission();_
} // end of write_io*
void knight()
x = read_io(0);
if (forward == true)
* if ( x == B10000000 )*
* // forward = true & x = B10000000*
* forward= false;*
* write_io(1,255);
_ }
else*
// forward = true & x not B10000000*
* x = x << 1;_
write_io(0,x);
_ }
if ( x == B00000001 )
// forward = false & x = B00000001*
* forward=true;_
write_io(1,0);
_ }
else*
// forward = false & x not B10000000*
* x = x >> 1;_
write_io(0,x);
_ }
} // end of knight*_
