I'm working on a program with an external interrupt. Thefore i have a button. But how often does the button swing (getting high and low), when pressed and released once?
erikv4:
Impossible to say and it won't be consistent. Google switch bounce.
Thanks 4 the advice.
"When the switch is closed, the two contacts actually separate and reconnect, typically 10 to 100 times over a periode of about 1ms."
Thats pretty much, what i get
erikv4:
I did some testing for this recently as similar questions come up often. I used an cheap button and oscilloscope, and got close to 20ms of bounce. As to how many bounces, no idea, a lot.
Please don't use interrupts for button presses, they are the wrong tool for that job.
The buttom is just 4 simulating a Schmitt Trigger circout, which unfortunatley doesnt't work the way it should.
But Thanks for your help
erikv4:
How should it work?
The standard hardware de-bounce circuit uses an RC low-pass filter to smear-out the bounces then a schmitt-trigger input to generate a clean logic signal edge from the analog voltage. Time constant of 10ms or thereabouts is typical. So 100k / 100nF RC filter into one section of a 74HC14 is a reasonable approach, and
the '14 can handle 6 switch inputs as its a hex inverter.
A workaround to handle multiple bounces can be added in the interrupt function:
volatile interruptFunctionCalled = false;
void myInterruptFunction()
static unsigned long triggedAt = 0;
if (100 < millis() - triggedAt) {
// add code to do whatever you like.
// ... such as setting a flag that this function has been called
interruptFunctionCalled = true;
triggedAt = millis();
