How pass two dimensional array to library function
I have the problem with passing two dimensional array to library function.
How to do it correctly?
Test.h
class Test
public:
	Test();
	void doTest(int** Input);
Test.cpp
Test::Test()
void Test::doTest(int** Input)
   int x = Input[0][0];
Test.ino
#include "Test.h"
Test test();
   int Input[11][4]= {
	{ 1, 0, 0, 0 },
	{ 1, 0, 0, 0 },
	{ 1, 0, 0, 0 },
	{ 0, 1, 0, 0 },
	{ 0, 1, 0, 0 },
	{ 0, 1, 0, 0 },
	{ 0, 0, 1, 0 },
	{ 0, 0, 1, 0 },
	{ 0, 0, 1, 0 },
	{ 0, 0, 0, 1 },
	{ 0, 0, 0, 1 }
test.doTest(Input);
The function has to know the array dimensions, or it can't calculate indices. So you have to declare all but the first array indices in the function declaration.
void Test::doTest(int Input [][4])IIRC
I think a safe solution would be to pass the first and second dimensions like this:
void doTest(int** Input, int iDim1, int iDim2);
// inside the function valid indices range would be
int iLowerLeft = Input[0][0] ;
int iUpperRight = Input[iDim1-1][iDim2-1] ;
// example...
int AnArray[5][6] ;
doTest (anArray,5,6) ;
Your function would know explicitly the limits to the 2D array.
As it stands it only knows there is a 2D array, but has no idea of the 2 sizes.
aarg:
IIRC
This works, but my Input can be different, with different number of columns and rows
I have tried this, but it didn't work
Test::Test(int y)
_y = y;
void Test::doTest(int Input[][_y])
shh_x3m:
Test::Test(int y)
_y = y;
void Test::doTest(int Input[][y])
I'm not surprised, as I said before, how could the compiler compute array indices? It can't do them dynamically. That's what you are asking it to do with [y].
