how receive string to arduino via enc28j60
Hello. Can anyone help with my code? I need to receive 1 or 0 from C# program running on my pc using ENC28J60 to lock or unlock door (access control system). I am using EtherCard library. The listening part should be in the big gap that I left. At the moment I am able to read card's UID, send it to C#, check database entries and probably send the 1 or 0 (the code for sending 1 or 0 from C# is bellow) back to Arduino. But I have no idea if the C# sending part is working, since I can't check the Arduino part. So can anyone help me?
C# sending part:
byte[] answer1 = Encoding.ASCII.GetBytes("1");
handlerSocket.Send(answer1);
Arduino part:
void loop () {
  normalModeOn();
  ether.packetLoop(ether.packetReceive());
  uid = "";
  if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial())
    for (int i = 0; i < 4; i++)
      if (mfrc522.uid.uidByte[i] < 0x10)
        uid += "0";
      uid += String(mfrc522.uid.uidByte[i], HEX);
    delay (100);
    Serial.println(uid);
    Stash stash;
    byte sd = stash.create();
    stash.print(uid);
    stash.print("/r");
    stash.save();
    Stash::prepare(PSTR("$H"), sd);
    ether.tcpSend();
    Serial.println("Packet sent!");
    //openDoor();
    mfrc522.PICC_HaltA();
    delay(100);
Since it appears you are using TCP/IP sockets you will need the TCP/IP library for the ENC28J60 Ethernet interface. You then need to use TCP or UDP to send data to your Arduino. UDP is faster but less reliable.
EtherCard library has TCP/IP library inside, but I still can't figure out how to receive data from C#... Any additional help?
