How retrieve and filter data from SD -Datalogger Min Max -
EXTRACT:
Currently I Made a datalogger, an Im saving data on a SD...But How can I retrive data from the SD?
I was thinking on a button to search MIN and MAX ...
Will be possible to make a new file each day at certain hour?
I have a datalogger...
This is the data Im storing on the file;
FECHA HR T1 T2 H1 T1 H2 T2
1 25/11/2015 06:47:20 42.75 38.5 67 44 73 42
2 25/11/2015 06:48:59 44.75 41.5 57 45 73 42
3 25/11/2015 06:49:59 45.5 42.75 56 46 68 45
4 25/11/2015 06:50:59 45.75 43.5 55 46 68 45
5 25/11/2015 06:51:59 45.75 43.75 58 46 70 46
6 25/11/2015 06:52:59 45.5 44 58 46 70 45
7 25/11/2015 06:53:59 45.75 44.25 58 46 70 45
8 25/11/2015 06:54:59 45.75 44.25 58 46 70 45
9 25/11/2015 06:55:59 45.25 44.25 59 46 71 46
All works good... I read the Read.file command from the sd..
But...
I want to be able to look in to the storing data
retrieving 4 lines and display on the lcd...
But how this will be done?
I guess I need to create 4 chars to retrieve the data
char line1[23]
char line2[23]
char line3[23]
char line4[23]
The main thing is I dont know how to read a line in the file
lets say line 1... to be able to index them and read from here...
Thanks in advance...
-Alex.
SD CARD DATA LOGGER FOR  MULTIPLES TEMPERATURE SENSORS
We will be using two temperature ds1820 sensors and
two humidity sensors.  to log data on to a SD.
//===============================LYBRAIES ================================//
#include <OneWire.h>                   //for the ds01820 always on the top
#include <SPI.h>                      //WARNING IN ORDER THIS WORKS PROPERLY
#include <SD.h>                       //THIS LIB MUST BE IN THIS ORDER.
#include "DHT.h"
#include <avr/wdt.h>
#include <MemoryFree.h>
//-------------for the ds 1820
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 10
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress probe1   = { 0x28, 0xFF, 0x08, 0x3B, 0x4A, 0x04, 0x00, 0xCA };
DeviceAddress probe2   = { 0x28, 0xFF, 0x16, 0x3C, 0x4A, 0x04, 0x00, 0x92 };
//-------------for the dht
#define DHT1PIN 4     // what pin we're connected to
#define DHT2PIN 5      // what pin we're connected to
#define DHT1TYPE DHT11  // DHT 11
#define DHT2TYPE DHT11  // DHT 11
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
//----------for the rtc1302 handling
#include <virtuabotixRTC.h>
//----------for the sd handling
const int chipSelect = 4; //FOR THE SD LIB
//==============================GLOBAL VARIABLES===========================//
//------------for the ds1820
float p1tempC = 0;
float p2tempC = 0;
boolean toprint = false;
char data[70];       // make a string for assembling the data to log:
char temp1S[6];      //variable to store the temperature in to char format
char temp2S[6];
byte second = 1;
byte pasSecond = 0;
char dthData[30]; // line for assembly the data of sensors
//------------for the rtc
unsigned int id = 0;
boolean save = false;
int dayofmonth;
int month;
int year;
int hour;
int minutes;
int seconds;
int dataROW = 0;
//===========================  CONSTRUCTORS ==============================//
// Creation of the Real Time Clock Object
  virtuabotixRTC myRTC(6, 7, 8);
//===============================VOID SETUP===============================//
  delay(2000);
  Serial.begin(9600);                                   // Open serial communications and wait for port to open:
  delay(2000);
  // for the dth handling
  //----------construct separate sensors
  dht1.begin();
  dht2.begin();
  pinMode(10, OUTPUT); // change this to 53 on a mega  // don't follow this!!
  digitalWrite(10, HIGH); // Add this line
  Serial.print(F("Initializing SD card..."));              // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect))
    Serial.println(F("Card failed, or not present"));      // don't do anything more:
    //return;
  Serial.println(F("card initialized."));
sensors.begin();                                       // Start up the library ds1820
sensors.setResolution(probe1, TEMPERATURE_PRECISION);  // set the resolution to 10 bit
sensors.setResolution(probe2, TEMPERATURE_PRECISION);
//-----print the header on sd and serial
 printheader();
//watch dog timmer to 8 seconds.
 wdt_enable(WDTO_8S);
//===============================VOID LOOP===============================//
  wdt_reset();                         //------watch dog timmer reset
  myRTC.updateTime();                  //----------keep ticking the clock
  if(myRTC.seconds == 1 )                  save = true;   //Serial.println(F("save is true"));
  if(myRTC.seconds == 59 && save == true ) second++;      //Take a measurement each minute
  if(second > pasSecond )
          dataROW++;                           //var to create an index
          getTime();                           //----------For get the complete date time
          sensors.requestTemperatures();       //-----For the temperatures readings.
          p1tempC = sensors.getTempC(probe1);
          p2tempC = sensors.getTempC(probe2);
          readDTH();                           //------read the two sensors dth
         // printDTHinfo();                      //------print the data on a single line
          assemblyData();                      //----------For assembly the data on one string
          Serial.println( data );              //----------Serial print of the data to save
          sdwrite();                           //----------we write to the sd
          pasSecond = second;                  //----------booleand guard to print just once per minute
          save = false;
       Serial.print(F("freeMemory()="));
       Serial.println(freeMemory());
      //    Serial.println("save is false");
//=====================  PRINT HEADER OF FILE AT STARTUP   ==============//
void printheader()
  Serial.println(F("Inciando recabo de datos"));
  Serial.println(F("  DATE - HOUR  T1 - T2 -  H1  -  T1  -  H2  -  T2 "));
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile)
    dataFile.println(F("Inciando recabo de datos"));
    dataFile.println(F("DATE - HOUR - MINUTE - SECOND - T1 - T2 -  H1  -  T1  -  H2  -  T2 "));
    //dayofmonth, month, year, hour, minutes, seconds, temp1S, temp2S
    dataFile.close();
  // if the file isn't open, pop up an error:
    Serial.println("error opening datalog.txt");
//===============================  GET DATE TIME  ======================//
void getTime(){
  dayofmonth = myRTC.dayofmonth;
       month = myRTC.month;
        year = myRTC.year;
        hour = myRTC.hours;
      minutes= myRTC.minutes;
     seconds = myRTC.seconds;
//===============================  DS1820 TEMP  ==========================//
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
   if (tempC == -127.00)
   Serial.print(F("Error getting temperature  "));
   Serial.print(F("C: "));
   Serial.print(tempC);
//=============================== DTH SENSOR READ==========================//
void readDTH()
  //this subfunctions call the sensors, read the values and
  //chek it for sessor data correct. Prints the values on
  //the global variables to be assembly in another function.
  //------------for the dht
float h1 = 0;
float t1 = 0;
float h2 = 0;
float t2 = 0;
char h1txt[6];
char t1txt[6];
char h2txt[6];
char t2txt[6];
    h1 = dht1.readHumidity();
    t1 = dht1.readTemperature();
    h2 = dht2.readHumidity();
    t2 = dht2.readTemperature();
  dtostrf( h1, 5, 2, h1txt);
  dtostrf( t1, 5, 2, t1txt);
  dtostrf( h2, 5, 2, h2txt);
  dtostrf( t2, 5, 2, t2txt);
  sprintf( dthData, "%s %s %s %s\0", h1txt, t1txt, h2txt, t2txt);
//=============================== SD WRITE ===============================//
void sdwrite(){
  if (dataFile)
    dataFile.println(data);
    dataFile.close();
    // print to the serial port too:
    Serial.println(data);
    Serial.println(F("error opening datalog.txt"));
}//--------end of sd write
//============================ ASSEMBLY DATA ===============================//
void assemblyData(){
        //dtostrf( [doubleVar] , [sizeBeforePoint] , [sizeAfterPoint] , [WhereToStoreIt] )
                                        //dtostrf(float, width, precision, buffer);
        dtostrf(p1tempC,5,2, temp1S );        //converts the temprature of the 1 proble from float to string
        dtostrf(p2tempC,5,2, temp2S );        //converts the temperature 2 from float to string
        //Serial.println("Assembly convert data  " );
        //Serial.println(temp1S);
        //Serial.println(temp2S);
        sprintf(data, "%d %d/%d/%d  %d:%d:%d  %s  %s %s\0", dataROW, dayofmonth, month, year, hour, minutes, seconds, temp1S, temp2S, dthData );   //Assembly the text on a single string
