How set digital point ON/Off every second? (Clock project)
Hi to all,
I’m building a clock with 2 x 7 segments display x 4 digits (so 2 display in total, every one with a 4 digit).
Every digit has the Digital Point. They are driven via a MAX7219.
I’m using LedControl library (https://playground.arduino.cc/Main/LedControl).
All works very well, but my goal is light the digital point of 6’digit for 1 second, and after 1 second light off. In same time last 2 digits need to be increment, of course.
WIth my demo sketch I got only to mantain light on or off every 1/2 sec. I would that 1 second it be on, 1 second be off.
This is current mode: 2017-12-17 20.35.37 on Vimeo
You can see the DP only half second. I would it 1 second.
This is my sketch:
 * Clock with RTC and 2 x 7 segments display
 * @ver 1.0
 * Testing from 17/12/2017
#include "LedControl.h"
#define PIN_DATA_IN 11
#define PIN_CLK     12
#define PIN_LOAD    13
#define NUM_MAX7219 1
 Now we need a LedControl to work with.
LedControl lc=LedControl(PIN_DATA_IN , PIN_CLK , PIN_LOAD , NUM_MAX7219);
 * Our setup.
 * @since 1.0
  setupMax7219();
  Serial.begin(57600);
 * Our loop
 * @since 1.0
  printHour(193200);
void setupMax7219() {
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,8);
  /* and clear the display */
  lc.clearDisplay(0);
void printHour ( long hour ) {
  //int ones, tens, hundreds, thousands;
  int digit_1 , digit_2 , digit_3 , digit_4 , digit_5 , digit_6;
  digit_6 = hour%10;
  digit_5 = ((hour/10)%10);
  digit_4 = ((hour/100)%10);
  digit_3 = ((hour/1000)%10);
  digit_2 = ((hour/10000)%10);
  digit_1 = ((hour/100000)%10);
  int i;
  for ( i = 1; i < 10; i++) {
    lc.setChar(0 , 0 , digit_1 , false);
    lc.setChar(0 , 1 , digit_2 , false);
    lc.setChar(0 , 2 , ' ' , false);
    lc.setChar(0 , 3 , digit_3 , false);
    lc.setChar(0 , 4 , digit_4 , false);
    lc.setChar(0 , 5 , ' ' , true);
    lc.setChar(0 , 6 , digit_5 , false);
    lc.setChar(0 , 5 , ' ' , false);
    lc.setChar(0 , 7 , i , false);
This is a demo, from 0 to 9. I know that I don’t need to use the delay and time is not right, but I need to understand the logic for that DP.
Thank you
You only need to update your display once a second, eventually this will be from whatever clock you use.
  static boolean dp=false;
  delay( 1000 ); // do everything once a second (from your clock eventually)
  printHour(193200);
Then, knowing it is only called once a second, you can flip the dp every time in printHour() like:
  static boolean dp= false;
   lc.setChar(0 , 5 , ' ' , dp );  // output digit with dp
   dp= ! dp;  // flip the dp for next time
    ... don't do any delays in here
Yours,
TonyWilk
Thank you.
I did move the bool dp = false at the beginning of sketch, and now it works!
Thank you!
