How should I connect tact switch?
int Buzzer = 7;    // 버저 핀을 7번에 연결
int Sensor = 9;    // 센서핀은 9번에 연결
int val;
int reading;
void setup () {
  pinMode(Buzzer, OUTPUT);   // 버저를 출력으로 설정
  pinMode(Sensor, INPUT);    // 센서값을 입력으로 설정
void loop () {
  val = digitalRead(Sensor);  // 센서값 읽어옴
  if (val == HIGH) {          // 장애물 감지가 안되면
    noTone(7);                // 버저가 울리지 않는다
    delay(100);
  } else {                    // 장애물이 감지되면
    tone(7, 220);             // 버저가 울린다
    delay(100);
    Serial.print(val);
I want to add tact switch in this code.
What should I do with this code if I want to make buzzer sound only when tact switch is pressed?
Use INPUT_PULLUP for the switch input. Connect the switch between GND and the input pin.
Do you want to use the switch together with the sensor input?
Hello kjg481268
Consider
uint8_t tactSwitch {10};
int val;
int reading;
void setup ()
  pinMode(tactSwitch, INPUT);    // 센서값을 입력으로 설정
void loop ()
  if (val == HIGH)
  { // 장애물 감지가 안되면
    noTone(Buzzer);                // 버저가 울리지 않는다
    delay(100);
  { // 장애물이 감지되면
    tone(Buzzer, 220);             // 버저가 울린다
    delay(100);
    Serial.print(val);
  digitalRead(tactSwitch) ? tone(Buzzer, 220) : noTone(Buzzer);
hth
I want to make buzzer ring only when switch is pressed.
Ok thx! I'll give it a try.
// Connect the switch between pin 9 and GND
int Tswitch = 9;
int val;
void setup () {
  pinMode(Tswitch, INPUT_PULLUP);
void loop () {
  val = digitalRead(Tswitch);
    delay(100);
    delay(100);
    Serial.print(val);
Sir, can I ask you how should I combine breadboard??
Connect your switch betweeh pin 9 and GND
