I am making a bob the biped robot which consists of 4 servo motors
i am using 4 AA batteries to power the servos
How on earth do I power the ARDUINO NANO
There is no power jack
What voltage battery do i use
This should be a pretty good place to start.
Can be done several ways.
USB power.
3.8volt to 5.5volt on the 5volt pin.
Make sure you haven't got anything connected to V-in.
If you plan to use analogRead, it usually has to be a solid 5volt.
~6volt to ~12volt on V-in.
V-in is the input of the onboard 5volt regulator.
The regulator drops it to 5volt when V-in is >6volt.
You could use a 9volt alkaline battery for a Nano.
It won't last long, but maybe long enough for your project.
Not wise to power the Nano from the servo battery.
Leo..
