How stop a loop, if the signal is still active
Hi, i have two inputs with wiring, the first, detect doors opens, and play sound 1, this sound turn off, when closed its doors.
The second sound, is welcome sound when turn on the engine car, but i have problem with the second sound, because it plays loop forever with welcome the sound because the engine is turn on.
I need to play the welcome sound every time the engine is beginning to work, but only once, the input signal never cut off, because the engine is turn on, it only cuts off when the engine is off.
The code:
# define ACTIVATED LOW
int btndoor = 7;
int btnwelcome = 6;
  pinMode(btndoor, INPUT);
  digitalWrite(btnpuerta,HIGH);
  pinMode(btnwelcome, INPUT);
  digitalWrite(btnwelcome,HIGH);
void loop(){
  if (digitalRead(btndoor) == ACTIVATED) {
    myDFPlayer.play(1);
    delay(2500);
  if (digitalRead(btnwelcome) == ACTIVATED) {
          myDFPlayer.play (5);
          delay (2000);
          myDFPlayer.stop ();
How i can stop loop?
You can't stop loop(). But you can put more conditions on the "if" statement. Perhaps adding a boolean being tested to see if this code has been run once already, do run it again.
How could I do that, I'm rather new to this topic. Excuse me and thank you.
Hi
I modified your code to use millis() instead of delay().
See if it works as you want.
Your code is missing the DFPlayer library.
#define ACTIVATED LOW
int btndoor = 7;
int btnwelcome = 6;
unsigned long time_door = 0;                // Time control for door
unsigned long time_weelCome = 0;            // Time control for wellcome
bool doorFlag = false;                      // Flag for run door play
bool wellFlag = false;                      // Flag for run wellcome play
int counter = 0;                            // Play 5 time only
  pinMode(btndoor, INPUT_PULLUP);
  //  digitalWrite(btnpuerta, HIGH);   ????  btnpuerta
  pinMode(btnwelcome, INPUT_PULLUP);
  time_door = millis();                     // Inicialize time_door control
  time_weelCome = millis();                 // Inicialize time_weelCome control
    if (doorFlag == false)                  // if not pass 2500 mseg
      myDFPlayer.play(1);                   // Play
      doorFlag = true;                      // Block repeat until 2500 mseg
      time_door = millis();                 // Reinicialize time_door control
    if (millis() - time_door >= 2500)       // If pass 2500 ms
      doorFlag = false;                     // Enable play
    if (counter < 5)                          // Play 5 times
      if (wellFlag == false)                  // if not pass 2000 mseg
        myDFPlayer.play(5);                   // Play
        counter++;                            // Icrement play counter
        wellFlag = true;                      // Block repeat until 2000 mseg
        time_weelCome = millis();             // Reinicialize time_weelCome control
      if (millis() - time_weelCome >= 2000)   // If pass 2000 ms
        wellFlag = false;                     // Enable play
    else                                      // If play more then 5 times
      myDFPlayer.stop ();                     // Play off
  else                                        // if btnwelcome is not ACTIVATED
    counter = 0;                              // Reset counte of play
