Hello
I did in the video project. Circuit 1 would like to add one more LDR
Exit People code :
Serial.print(1-counting);
How do I
2 LDRinput and output ?
int ldr = 0;
int ldrValue = 0;
int ldrTemp = 0;
int ldrMin = 1023;
int ldrMax = 0;
int ldrCompare = 0;
int setldrMin = 0;
int setldrMax = 0;
float setPercentMin = 0;
float setPercentMax = 0;
int counting = 0;
int ser;
int Max = 0;
int Min = 0;
Serial.begin(57600);
pinMode(10, OUTPUT);
Serial.println("LDR counter by krangul");
Serial.println("To [c]alibrate laser press: c");
Serial.println("To [t]est min/max value press: t");
Serial.println("To [s]et min/max value limit press: s");
Serial.println("To start counting [m]easure press: m");
Serial.println(".............................................");
Serial.print("Your ldrMax limit value: "); Serial.print(ldrMax); Serial.print(" - "); Serial.print(setPercentMax); Serial.print("% = "); Serial.print(setldrMax);
Serial.print("Your ldrMin limit value: "); Serial.print(ldrMin); Serial.print(" + "); Serial.print(setPercentMin); Serial.print("% = "); Serial.print(setldrMin);
while(Serial.available() == 0);
ser = Serial.read();
for(ser; ser == 'c' || ser < 0 ;)
calibrate();
for(ser; ser == 't';)
test();
for(ser; ser == 's';)
set();
for(ser; ser == 'm';)
count();
void calibrate()
for(int b=0; b<250; b++)
read_ldr();
Serial.println(ldr);
delay(100);
void test()
read_ldr();
ldrCompare = ldr;
if (ldrCompare > ldrMax)
ldrMax = ldrCompare;
if (ldrCompare < ldrMin)
ldrMin = ldrCompare;
delay(30);
void set()
Serial.println("Set your Min percent limit 10-40%");
for(int c=0; c<2; c++)
setPercentMin *=10;
setPercentMin += (Serial.read() - '0');
Serial.println("Set your Max percent limit 10-40%");
for(int d=0; d<2; d++)
setPercentMax *=10;
setPercentMax += (Serial.read() - '0');
setldrMin = ldrMin + (ldrMin * (setPercentMin*0.01));
setldrMax = ldrMax - (ldrMax * (setPercentMax*0.01));
void count()
Serial.println("#####################################");
Serial.println("## Measurement has been started. ##");
for(;;)
read_ldr();
if(ldr>setldrMax)
Max=1;
if(ldr<setldrMin && Max==1)
Max=0;
counting++;
Serial.print(counting);
tone(10, 6000, 10);
void read_ldr()
for(int a=0; a<10; a++)
ldrValue=analogRead(0);
ldrTemp = ldrTemp + ldrValue;
delay(1);
if(a==9)
ldr=ldrTemp/10;
ldrTemp=0;
