How to access a void loop data and send it to SPIFFS
Hello,
I have a void loop which contain a `variable int bleNumber and hold sum number. it always has a data from foundDevices.getCount();
    recvWithStartEndMarkers();
    if (newData == true) {
        strcpy(tempChars, receivedChars);
        parseData();
        showParsedData();
        newData = false;
    BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
    Serial.print("Devices found: ");
    int bleNumber  = foundDevices.getCount();
    Serial.println("Scan done!");
    pBLEScan->clearResults();   // delete results fromBLEScan buffer to release memory
    delay(2000);
Now i need to send this number to server so i am using spiffs it is in void setup()
server.on("/blenetworks", HTTP_GET, [](AsyncWebServerRequest *request) {
        request->send(200, "text/plain", String(bleNumber).c_str());
But i am getting confused how should i store this value globally in the sketch so that it could get access by void setup whenever the new data it should also be updated in that global .
You have not posted a complete sketch so the problem cannot be seen in context but you have answered your own question
Declare the variable as a global and don't declare a second variable with the same name anywhere else in the sketch
#include <HardwareSerial.h>
#include <WiFi.h>
#include <WiFiManager.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include "SPIFFS.h"
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
int scanTime = 5; //In seconds
BLEScan* pBLEScan;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      Serial.printf("Advertised Device: %s \n", advertisedDevice.toString().c_str());
boolean newData = false;
AsyncWebServer server(80);
HardwareSerial SerialPort(2);
int bleNumber; // DEFINE HERE
String networkNumber = "";
    SerialPort.begin(9600,SERIAL_8N1, 16, 17);
    WiFi.mode(WIFI_STA);
    WiFi.disconnect();
  //SPIFFS
    int numberOfNetworks = WiFi.scanNetworks();
    networkNumber += numberOfNetworks;
    Serial.println(networkNumber);
    if (WiFi.status() != WL_CONNECTED) {
        WiFiManager manager;
        bool success = manager.autoConnect("rootofpisniffer","12345678");
        if(!success) {
            Serial.println("Failed to connect");
        else {
            Serial.println("Connected");
    if (!SPIFFS.begin()) {
        Serial.println("An error has occurred while mounting SPIFFS");
    }else {
        Serial.println("SPIFFS mounted successfully");
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
        request->send(SPIFFS, "/index.html", "text/html");
    server.on("/noofnetworks", HTTP_GET, [](AsyncWebServerRequest *request) {
        request->send(200, "text/plain", networkNumber.c_str());
    server.serveStatic("/", SPIFFS, "/");
    server.begin();
    BLEDevice::init("");
    pBLEScan = BLEDevice::getScan(); //create new scan
    pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
    pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
    pBLEScan->setInterval(100);
    pBLEScan->setWindow(99);  // less or equal setInterval value
    delay(2000);
i DID THIS I GET A VALUE AS 0 IN SERVER I AM USING JAVASCRIPT TO DO THIS
This is a local variable, it's not the same variable as the one declared in the global scope
So how can i passed the value to the global variable ?
You don't need to pass a value to a global variable. If you update its value anywhere in the sketch then the new value is available to be used anywhere in the sketch
so i provide varaible bleNumber to spiffs directly . but when it runs it will throw me error .
Post the code that causes an error where you declare bleNumber only as a global and not locally
